The pc has AMD Athlon (tm) processor 3500+ 2.20 ghz 2.00 gb of ram. It runs windows xp but I need to know what I need to upgrade to run windows 10.
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
SOURCE: Lacie Silverscreen 80Gb Drive not recognised by My Dual Processor PC
Sorry for the late reply, but it may help someone else with the same problem.
Are you using a USB2 port, perhaps it's may not be getting enough power. In the orginal Lacie box was a double USB dongle - it allows you to take the power from two USB ports and send them to the Silverscreen, if the SScreen was getting quite enough power.
Or buy a double USB power cable (like: http://www.n-c.fr/webshopncrevendeurs/catalog/images/Double_Cable_USB.jpg)
Otherwise remove the 2.5" disk (remove two screws, & gently pull out) and use a caddy to check the HD disk is still working.
SOURCE: HOW CAN I UPGRADE MY SYSTEM
it depends on how big the ram and the hd is. the bigger the hd and ram the more expensive it is except for their transfer rates. if your planning on upgrading because of games, you will need atleast 7200 rpm for the hardisk which costs more than a typical one. but for all i know thats the default for a desktop. there are 10,000 rpm also which are more expensive than the bigger hd's. same with the RAM. you can check ebay for the price. but the price depends on the country you are in if your buying it from your place.
SOURCE: unable to install canon software in windows XP Prof with AMD pro
try downloading the version from the canon website
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=225&modelid=17480#DownloadDetailAct
SOURCE: Can I play Command and Conquer Red Alert 3 on this computer?
I am going to say yes. I have basicaly the same as you. The game will lag a bit unless you trun down the settings (Visual) to low. You wont notice the difference in how it looks, but the game will play better. the game is worthe it.. I love it.
If you get it going look me up on the game Pincushion_LTC..
Let me know how it goes..
SOURCE: halo is running slow in vista here is my system
maybe your graphic card's video memory is too low... just buy another one or upgrade it
