Dennis Sapp Posted on Mar 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get to the inside of my hp All IN one printer, Model L7780 to connect the multi-wire planar cable from the control panel to the back of the printer.
Andrew Henderson
Level 2:
Sergeant:
  • HP Expert 394 Answers
  • Posted on Mar 20, 2019
 Andrew Henderson
HP Expert
Level 2:
Sergeant:
Answers
394
Questions
0
Helped
157789
Points
830
You will need to take the side panels off to get to the circuit boards. The Main board is often on the right hand side when looking from the front
Testimonial: "I know the side panels need to come off but they will not budge even tho I've taken out all the screws."
5 Related Answers
Anonymous
  • 84 Answers
  • Posted on Jul 12, 2007
SOURCE: repairing tips for Hp deskjet 1125c Inkjet Printer
It may be the rollers that grab the paper and pull them into the tray, over time they start wearing down and losing their grip, kind of like a car tire. There are rejuvinator pads available that will give the rollers a little big of their grip back but I don't know how effective they are because I've never used one.
Anonymous
  • 7 Answers
  • Posted on Aug 11, 2007
SOURCE: Monsoon Planar Media 7 audio system control center
www.Ebay.com =)
Anonymous
  • 5 Answers
  • Posted on Apr 29, 2008
SOURCE: Monsoon Planar 9 multimedia
ebay!
A
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Planar PCI device does not respond or disbale by user
this is not an error message, see: http://www-304.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-41551
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
  • Posted on Jul 06, 2010
SOURCE: OfficeJet Pro L7780 controls non-responsive
There is conflict between the Printer and Router you are using. The Router is freezing the printer connectivity to the network due to the Wireless radio ON option in the printer
There is a firmware update for your printer, Let your printer be connected thru USB and from this link, download and install the update for your printer and later try setting it up wireless, it should work.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62339-2&lc=en&dlc=en&cc=us&os=2093&product=2512010&sw_lang=
If this step fails, the other step is, to Enter the printer IP Address manually in the printer Network menu from SEtup Option and later run the wireless setup wizard to connect it to the network.
HP Scanner L7780 Ribbon Cable Magnets required?
If you have the old cable, you put them in the same place. If not, evenly spaced. They are ferrite magnets and are there to stop interference.
No one has documented this job yet.
https://www.google.com/search?q=HP+L7780+replacing+the+scanner+and+control+panel+ribbon+cables
HP L7780 wiring schematic
To obtain a wiring schematic or service repair manual for the HP Officejet Pro L7780 Printer, I recommend reaching out to HP directly. You can visit the HP Support website and navigate to the product support page for the L7780 printer model. There, you should be able to find relevant documentation, including service manuals or wiring schematics, that can assist you with your specific needs. HP's official support channels are the most reliable sources for obtaining accurate and up-to-date information for their products.
These videos might help
1helpful
3answers
I installed hp officejet pro l7780 but failed to calibrate.
Partial reset the printer
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
I have an HP L7780 that I can print to - - but when I try to scan an error message comes up saying "No HP device has been detected"
check cable connection, check at contol panel printer and fax, select the print that online, may you chose print that offline
i hope this helpfull, please rate very helpfull or helpfull if you think this helpfull
thanks for using fixya
I have mac laptops and hp laptops. My mac laptops print wirelessly to my hp L7780 and my hp laptops have trouble
exactly what kind of trouble , it can be related to any internet security or antivirus installed in ur HP laptop which is blocking IP of the printer to connect to ur Laptop and print . pls go to controll panel of ur Windows Os in HP laptop and uninstall the Internet security from HP laptop
Control panel on HPL7780 locked up after trying wireless set up
in this model there is a problem with wifi connection, hp has just released its patch, connect the printer with usb cable and then donwload the patch from hp.com/support and then run the patch, it will find the printer and it will update the firmwar of printer, and i asure u that then it will start working fine,i have resolve this problem alot, i am from hp itself. :)
6helpful
Hp officejet l7780 rear access panel is open it not! need to reset
The L7780 usually has a duplexer which has a rear access panel on it but this is NOT the panel that the printer detects as open.
In the L7780 anything that is connected/slotted into the rear slot/hole is considered to be the rear access panel. This means the duplexer (which is standard on the L7780) is seen as the "rear access panel".
Stand looking at the back of the printer
Inside the slot on the right side you will see a green circuit board with four metal contacts on it. Check that these are not soiled or damaged in any way. Clean if necessary.
On the right side of the dupler you will see only TWO metal pins that spring out and should make contact with two of the contact points. It's possible that these are damaged and/or broken. You may need to free, re-bend, etc... these CAREFULLY so that they stick out properly. Ultimately the goal is to ensure that the metal pins touch the appropriate contacts on the circuit board.
If all else fails, check your warranty and contact HP to see if they can provide a replacement duplexer. If the circuit board itself (in the printer) is damaged though you may need to return the printer itself.
Hope that helps.
Officejet 5510 Scan Function disappeared
HP has a fix for the Internet Explorer 7 issue on it's download page. You can also install the full feature software for a newer model, I used the OfficeJet L7780 and I now have additional features plus it works in VISTA. Just be sure to select "WIRED/WIRELESS" when asked how to connect and select "CONNECT LATER" when prompted that the printer could not be found. Works great.
k24674
Grand Canyon Tech
Grand Canyon Tech
