Washing Machines Logo
Tiarelle Gokul Posted on Mar 20, 2019
Hi my machine when pluged into power it comes on an the washer in the drum is spinning but it has a bad hum what can be my problem
5 Related Answers
Anonymous
  • 185 Answers
  • Posted on Mar 25, 2008
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Anonymous
  • 639 Answers
  • Posted on Aug 30, 2008
SOURCE: Washer/Dryer is not spinning
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could make this sound first, like a knock,knock,knock or klack, klack,klack
OR,SOMETIMES JUST NO SOUND AT ALL AND JUST NOT CONNECTED FROM THE TRANSMISSION TO DRIVE THE ROTATION OF THE TUB!
This means you need parts! and service!
How old is the washer if it is 10 years old or more I recommend being prudish about investing a lot of money in to it!
The newer models are so much more energy efficient, that they save you water,gas or electricity And detergent too!
They can pay for them selves in energy savings in a few years!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 04, 2008
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Anonymous
  • Posted on Feb 01, 2009
SOURCE: Why won't the drum spin on my LG Tromm front load washer?
I had the same problem and it was a bad sensor assembly (#6501KW2002A). You can order
it from an online electronics store (www.mcminone.com). Cost is approx. $20.
I fixed it based on a thread from 2007:
See http://www.fixya.com/support/t159708-lg_washer_wm1832c
But, here's what I did:
1. Unplug the machine.
2. Take off the back plate that has 4 small screws.
3. Unscrew the big bolt in the middle.
4. Take off the hubcap looking part the bolt was securing.
5. Unclip the two sets of wires on the bottom of the circle you are looking at
(the set of wires to the right are connected to the sensor assembly you want to replace).
6. Unscrew the 6 smaller bolts to take off the circular piece that the sensor assembly is snapped to.
7. Mark with a pen where the sensor attaches so you know where to snap the new one.
8. Unclip the old sensor assembly and clip on the new one
9. Reassemble.
Anonymous
  • Posted on Mar 30, 2009
SOURCE: kenmore 700 series washer motor humming noise
ffsdaffdsa
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Front end washer not washing or turning all u hear is the motor what causes this to happen
Hi Arthur Williams, this is AP! Thank you for your post.
I understand you are having trouble with your front load washer not spinning, but you can hear the motor. There are many situations that could prevent your drum from spinning. Overuse of detergent can result in too many suds restricting the tub from turning properly that will not spin out. Is the washer making a humming noise? Try putting the washer on spin only, if the drum will spin then it could be kinked hoses, if not it could possibly be the motor or the door lock assembly, timer, pump, control board not communicating. I would recommend having a technician come out to diagnose your front load washer. I hope this information proves helpful for you.
Thanks,
Have a Fisher & Paykel GW712 washing machine. Initially - with the power on at the wall and not turned on at the machine - there is a hum coming from the machine. The washer did not work (agitator...
Hi just read your posting.Now when you hear the humming noise, even though the machine is not powered up, is the noise comming from the top near the MOTOR CONTROLLER? Why did you replace the RPS ?If the hum is coming from the CONTROLLER then your CONTROLLER might be faulty.When the machine is not powered up no noise should come from it at all.Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
Makes a humming noise but then nothing
the motor is bad. it will need to be replaced or purchase a new unit ( depending on cost of repair ). Joe
2answers
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Top Washing Machines Experts
john h
