I need to know the exact size of the tubes for this Bearfoot lll amplifier. The tubes do not have the no.s on them, they have faded off. The tubes light up but my amplifier is not working. There is no place here to have them tested. The tubes have 12 pins on them & there are 3 tubes.
Google:
BearFoot FX Amp-in-a-Box Effects Pedals
https://www.bearfootfx.com/product-category/amp-in-a-box/ ... BearFoot FX · SALE! Contact · BearFoot FX Amp-in-a-Box ... bearfoot fx $169.00. Dyna Red Distortion 3-Knob (Marshall Style AIAB). Add to cart · BearFoot FX ...
Videos There are several on Youtube
SOURCE: NEED TO KNOW SIZE OF CAP TUBE FOR A MODEL 3 F
call e-mail the manufacture if you can get the oem parts for the cap tube size I'd need the horse power of the compressor.
SOURCE: Color code for 4-pin Cobra M75 CB Mic
here is the link that i used
hope it helps
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=8197
SOURCE: i have 3 hifonics zeus
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
SOURCE: Oil pan removal- 12 point bit size?
I don't know what size they are, but the sockets are available at auto parts stores. They may know the size or you could try a couple to get the right one. I hope this helps you.
SOURCE: 1996 hd 1200 xlh blinker wont work
I'd guess I would say,next check for 12 volts at pin 7 withe left turn button depressed and you say it worked,right? No? Check flasher unit for left side.Is your speedo doing strange things to?Check alarm system.Don't know why but anti-theft feature messes with left turn signal and speedo function.Disconnect neg. wire at battery,then reconnect and reset the alarm in usual way for when it goes off.[will go off when neg is reconnected].
