How can i force stereo (i dont want dolby 5.1) on my tcl lcd advanced menu?
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Oct 17, 2008
SOURCE: cassette is stuck in the my stereo
it sounds like a mechanical push open/close, but if it is solenoid then you will have to open it up and find out what has it jammed. my best advice is to take it to a service center and have it worked on.
2answers
How to order a replacement screen for a 55in TLC television please?
Question edited for clarity.
Question moved from Cooktops!
TCL TV Parts ' ShopJimmy - ShopJimmy.com Ad·https://www.shopjimmy.com/
The Online Leader In TV Repair And Replacement Parts. Check Out Our Huge Inventory Today! TV Repair Made Easy. Servicing All TV Brands. Repair Kits Available. 180 Day Warranty. Brands: Samsung, Vizio, LG, Sony, TLC, Sharp, Panasonic, Insignia, Hisense.
"); background-size: 13px 15px; background-repeat: repeat-x; font-size: 0px; line-height: 0;">") 0px 0px / 13px 15px repeat-x; line-height: 0;"> Rating for shopjimmy.com: 4.5 - 369 reviews
TV PartsTV Boards, Cables, Lamps, Remotes, Speakers, Stands, Tools, And More!
Appliance PartsShop Parts For All Appliances Such As Fridges, Dryers, Stoves & More!
TCL TV For Parts On eBay - Seriously, We Have TCL TV For Parts
Ad·https://www.ebay.ca/
Looking For Great Deals On TCL TV For Parts? From Everything To The Very Thing. All On eBay. Get TCL TV For Parts With Fast And Free Shipping For Many Items On eBay. Register Online. View Deals. Shop Online.
55S535 TCL 55-Inch Lcd Tv Replacement Parts
Ad·https://www.encompass.com/
We are a leading supplier of OEM replacement parts for all needs. Fast Shipping. OEM Parts.
‎View All Brands · ‎Sharp · ‎Samsung · ‎Browse Appliances · ‎Consumer Electronics · ‎Panasonic
Search Results
TCL 50" and larger TV Parts and Accessories - PartStore.com
https://partstore.encompass.com > modelbrowse > TCL
TCL 50" and larger TV Parts and Accessories. TCL Replacement Parts ... 55 Inch Class P6-series 4k Uhd Dolby Hdr Roku Smart Tv, 15.
I have receiver THIS MORNING PLAY I COMFUSE WHY THE BOTTOM OF DSP, DSP LOGIC, BYPASS,DOLBY PRO LOGIC,DOLBY 3 STEREO BECOME ON INTERCHANGE. LET SAY WHEN I PRESS THE BOTTOM DSP LOGIC ON THE SCREEN IT SH
Get a better translator. Sounds life bad solder job on board. Check buttons wire connections and where they hook up. If it'd the display which I Dont think it is try checking those wires. Good luck.
25helpful
Samsung ht-c550 dolby pro logic II mode does not work.
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
2answers
Right now my reciever will only play with two speakers (L and R). How do I get the 5.1 DTS back?
Are you using single digital coaxial or optical digital or the stereo RCA cable.
You might have that buttons on the remote for surround,2channel,3channel or 5.1 channel. orGo to the DVD's setup menu and click on "Audio Setup" or on "Languages" if there is no Audio Setup option and choose "Dolby Digital 5.1." (If you have a5.1, 6.1 or 7.1 system select "Dolby Digital EX" if it is an available option.) Depending on the age of the disc, the "Audio Setup" on the DVD menu may give you several choices: "5.1 Channel Surround Sound" or "Stereo Playback." If it's an old DVD, it might even say Dolby AC-3 (the professional designation for Dolby Digital 5.1). New DVDs may offer "Dolby Digital 5.1" and "Dolby Digital 2.0," the latter being stereo. Some of the disc menus offer only "Surround Sound" or "Stereo" options.
10helpful
2answers
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
2answers
Volume trouble with 37LG30
well if you want to get rid of he tv i offer to buy it from you
[email protected]
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
 Grubhead
Grubhead
SmartAviator
SmartAviator
