Vacuums Logo
Jill Magan Posted on Mar 20, 2019
George Wet Vac has been working fine but just changed water during carpet shampoo and now spraying out at right angles, rather than 45 degrees into the nozzle. Any ideas? I didn't change anything else
Chris
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 05, 2022
Chris
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
14
Questions
0
Helped
11209
Points
25
Check jet nozzle hast got anything stuck in it eg grit
5 Related Answers
Anonymous
  • Posted on Jul 14, 2008
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Anonymous
  • Posted on Jul 23, 2008
SOURCE: Eureka Atlantis 2591A Extractor - Won't spray
no sray water
Anonymous
  • Posted on Jul 30, 2009
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
thevacdudes
  • 37 Answers
  • Posted on Aug 29, 2009
SOURCE: My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Testimonial: "many thanks for your help l will take a look at the shampooer and if I feel I know what Im doing I'll have a go myself if not I will contact service "
Anonymous
  • 302 Answers
  • Posted on Oct 14, 2009
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 • Vacuums
5helpful
I cant figure out how to **** up water with my kirby dimond
Vacuuming a wet carpet with your Kirby or any other vacuum not designed for wet pickup could do serious damage to your machine and there is a real danger of electrical shock to the operator.
Your Kirby Diamond and every other Kirby for that matter is NOT designed to pick up water!! Even with the shampoo system attached it will NOT pick up water or the shampoo foam. Your Kirby spreads the shampoo foam around on the carpet to clean it. You then only vacuum a shampooed carpet after it has completely dried.
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
1helpful
NO WATER COMING OUT FOR SHAMPOOING /DUMPS WATER WHEN UPRIGHT
there is a belt inside that runs the pump to spray the water. I would take it in a have it replaced. Mine did the same exact thing.
My bissell deep clean carpet shampoo machine does not spray,
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yfggf
For the first time, I tried using my Kirby Sentria shampoo attachment. I've lost the manual but found instructions online for making the swap from regular vac to shampoo-er and got it all assembled. The...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=638285
Generic problem for all Vacuums
Posted by MHicks on Jun 01, 2008
For the first time, I tried using my Kirby Sentra shampoo attachment. I've lost the manual but found instructions online for making the swap from regular vac to shampoo-er and got it all assembled. The foam laid down just fine; however, when I run the vac back over the foam to pick it up, there is not a stitch of water showing up in the tray. First I thought maybe it was bc I hadn't put that much of the foam/water onto the carpet, but 12 hours later, the carpet is still wet in spots. Clearly my assembly wasn't 100% but I don't know how to figure out what's wrong. Help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In a case like this I would contact the factory, by the sounds of things you did everything right but it is a dry foam shampoo and some moisture will get into the carpet. I will list the Kirby factory phone 3 listed below for your assistance with this problem. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/Contact Us by Phone
United States and Canada: 1-800-494-8586
Between the hours of 8 a.m. – 5 p.m. (EST)
Monday - Friday
United Kingdom: 0800-328-1247
Europe: 00-800-5472-9272
South Africa: 0800-203-222
Contact Us by Email
Complete the online Form to Submit Your Comments or Questions
Contact Us by Fax United States and Canada: 216-529-6146
Contact Us by Mail
Consumer Relations Department
The Kirby Company
1920 West 114th Street
Cleveland, OH 44102
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 01, 2008 • Vacuums
2answers
George
Hi.
No the switch for the pump will work without main vacuum switched on.
Your problem could either be faulty pump switch or faulty pump,
You should be able to get spares relatively easy from any independant vacuum repair shop.
Dont try currys etc they wont have a clue what your talking about.
http://dysonmanuals.llc.nu/
Chris.
9helpful
2answers
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
