SOURCE: Excel not importing dates as given by accounting package
Dear Valanti,
This implies that basically the versions are causing the problem and there are compatibility issues with your program. I would suggest that you should copy the report files to a detachable media and transfer it to your new system because this is a one time process.
You can also install the same version on both PCs. You can also do following for tracking changes in documents:
If that was helpful, please press solved.
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
SOURCE: Configuration error Sony Ericsson w300i
Try flashing your phone with the Sony Ericsson update service.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w550i?cc=gb&lc=en
SOURCE: PROTECT
Are your speakers shorting? Try running it with no speakers, see if it does the same. If it still does the same, like I've posted 3 times now, There is something shorting inside, or something finished. The system locks to PROTECT itself from short damage. Make it repaired if you can't do it yourself. (CAREFUL: If you open it yourself, this system's amplification system contains high voltage, it can shock you really bad if you touch something bad, even if unplugged!) Or buy a new one, like I did, new brand, new model, This jvc one has done it's time.
