Question about Frigidaire Kitchen Ranges
The clock blinks on my frigidaire stove the past couple of days it resets just fine
SOURCE:
Krazytech
  • 725 Answers
SOURCE: Frigidaire gas oven locked problem
you have a short in the Electronic Oven Control. if no error codes only two in this EOC
F1 or F3
Posted on Sep 13, 2008
Krazytech
  • 725 Answers
SOURCE: FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Posted on Sep 29, 2008
SOURCE: Frigidaire Stove clock resets to 12:00 when igniters turned on
I have the same problem. This is an intermittent problem, maybe once every 20 to 30 starts the clock goes resets and the appliance beeps just like if unplugged it and then plugged it in again. I’m an electrical engineer and this sounds like the microcontroller that runs the appliance is being reset by noise caused by the spark igniters. This is definitely a design problem. Separating the wiring of the igniters and the control board should help. When I get a chance I’ll have to connected an oscilloscope and look at the noise. The control board microcontroller reset pin probably needs an RC snubber or an isolated ground. If /when I find something more definite, I’ll place another posting.
Posted on Jan 18, 2010
BIKER T
  • 909 Answers
SOURCE: clock frequently goes blank and needs to be reset
You have a faulty display module due to one or more components leaking. Some models have a seperate display module that can replaced without the complete board having to be replaced. If not, the board needs to be replaced. You need to ask your spares suppliers that have info. on that model.
Posted on May 21, 2010
  • 1531 Answers
SOURCE: frigidaire coil burner stove has digital clock
you need to check the wires to the electronic control board and make sure all connections are good. if there is no problem with the wiring or main power then you will need to replace the electronic control board.
Posted on Sep 21, 2010
My stove panel went blank.
You will need to replace the clock/timer on the unit. Here is that part to order.
Frigidaire 316557114 Clock timer AppliancePartsPros com
Mar 22, 2014 | Kitchen Ranges
The only thing working on my stove is the clock???
I had this problem the other day with a customer stove. It turned out his outlet had a bad connection and the prongs were fried. His stove was getting less than 120 volts where as it needs 240 volts for anything aside from the clock to run.The solution was to replace the wall receptacle and the cord to the stove.To see if you have this problem start by unplugging the stove to see if the prongs on the plug are burnt. If they look clean then this is not your problem.
Check your breaker box, there are two breakers for your stove outlet. Sometimes one of them could be tripped off causing this same problem. Reset both breakers for your stove regardless (If resetting your breaker fixes the problem but it trips again, have your stove inspected).Hopefully this helps
Apr 05, 2013 | Frigidaire FEF326 Electric Kitchen Range
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool stove clock malfunction..
you have a bad electronic oven control or in other words bad clock
Dec 30, 2008 | Kitchen Ranges
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
F1 or F3
Sep 13, 2008 | Frigidaire FEF336BC Electric Kitchen Range
FRIGIDAIRE STOVE
Aug 29, 2008 | Frigidaire FEF355 Electric Kitchen Range
F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Dec 20, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
