My Schlage lock is no longer locking my door. It looks as though the door might have slipped down from the top and now the lock is slightly off and keeps the door from locking. When I pull up on the door then I can get the lock to line up correctly. How can I fix this?
SOURCE: Schlage electronic keypad lock doesn't work
I have the same/similar problem. I called the company 888 number. The customer rep promised to send me a new one. good luck
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
SOURCE: Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Testimonial: "I will try your suggetion. Thank you."
SOURCE: My schlage door knob lock tumbler stopped working
if the cylinder in the lock is not turning anymore when you put the key in -- then there could be a stuck pin inside the cylinder. use a teflon or silicone based lubrication and spray into the key hole and cycle the key in and out a few times and then spray some more lube in and cycle the key some more,, spray one more time and let it sit for awhile --- after sitting for awhile, try the key again.
if it still wont turn the cylinder then it needs to be rebuilt,, take the lock down to your local locksmith shop and have them rebuild the cylinder to the key you want. the cost of this is only about 8.00 to 10 dollars ( depending on where you live ) and it only takes about 5 minutes.
now there is also a chance that the lock might have another issue going on here --- if you remove the knob from the door and with it in your hand, try the key and see if it turns left and right,, if it does turn then the problem is not the cylinder but the thumb turn part of the lock jamming up,, you can also take the parts to the lock shop and get a replacemnet pretty cheap.
one more thing to check is to make sure the lock is not to tight on the door -- and what I mean by this is that on some hollow doors they get squished in to the point where the lock/unlock part of the lock drives into the thumb turn part and it has way to much pressure on it. again - if you remove the lock from the door it should all be pretty clear what is the problem here.
c...
