I have a 2004 John Deere Buck 650. Why is there oil getting into the air filter box? I found an oil leak in the upper part of the engine as well, it was coming out of a bolt type thing that had a wire connected to it.
SOURCE: peg-perego John Deere buck EXT reads fully charged, but won't go.
I would replace the high/low switch and the reverse switch.
You can get the peg perego parts at http://www.shopjandl.com/
but I would first check the connections on the motors and foot switch. Sometimes they come loose.
Hope this helps
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: looking for a free download for a john deere model 650 owner's ma
http://www.ssbtractor.com/tractors.cgi?m=john_deere
www.deere.com/en_IN/home.../OMPY0146_19_22AUG06.pdf
www.tractorbooks.co.nz/Tractor%20Manuals.pdf
SOURCE: Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
SOURCE: We have a John Deere lawn mower model JS45. Just
this problem is related to the auto-snesing carburator. If you wrap the throttle cable, that runs down the left side of the mower, around the handle several times and tie wrap in place the mower will run. I had the same issue with mine. the manual is vague at best when it describes how to fix. After you wrap the cable around the handle, it will tighten the cable and the mower will run.
JV
Boot was supposed to be (bolt)
