SOURCE: espresso maker
gose to : http://www.krupsusa.com/NR/rdonlyres/6907301C-7474-4ECF-857D-650657C83A4C/7923/FND1.pdf
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: I have more of a question then a problem.
Well maybe you can go back to the store you got it from and ask them what size is the bar pump.
SOURCE: We understand that your problem
Based on the information provided above the machine is a bit old as 3 years of regular use is quite a while. If the frothing wand is the only part of the machine which leaks water it can be presumed that a replacement of the part is in order.
It will be advicable if you can afford a new machine to get a new one otherwise get an expert to replace the frothing wand and run a general service of the entire machine.
Water leakages around electrical appliances are very dangerous and the consequences are always disastrous. So ensure that either the device is handled by an expert or replace the unit completely.
Hope this solution has been helpful?
SOURCE: Delonghi Espresso Maker Issue
You should check these issues to troubleshoot:
1) Is coffee grind too fine?
2) Coffee grinds packed too tight in the basket / portafilter?
3) Rain screen clogged (where water is pumped through into the basket)?
4) Pump starting to fail and not enough pressure created to properly pump water through grinds?
5) Maybe the machine meeds to be descaled.
