Sewing Machines Logo
How to thread an overlocker from dunelm dm511
1 Related Answer
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Jul 12, 2012
SOURCE: need help threading a dunelm mill sewing machine
email these sites & see if they can help you with a manual
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
How to thread my overlocker 654
Hi Dear,
elna-654-frlgxdwgqgcxp3mkytozumx2-3-0.jpg For Elna 654 overlock Machines Elna 654 Serger How to thread for 4 thread overlock tips tricks
For Juki 654 overlock Machines Juki 654de Serger threading
Best of Luck
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Foot pedal for sew easy dm511
try these sites
sewvacdoctor.com
1helpful
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
2helpful
2answers
Need help threading a dunelm mill sewing machine
sewusa.com
sewvacdoctor.com
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
