Model # LW1216ERY7
SOURCE: maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely if not the bearings have seized up. So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem. IF the fan spins freely OHM out the fan and make sure there is no shorts or openings in the fan. if your fan motor checks out good both mechanically and electrically then your next step is to check the capacitor and control board
SOURCE: LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
SOURCE: I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
SOURCE: compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
