Grilling Logo
D
Deborah Motz Posted on Mar 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find replacement parts for model C878-62 Cast Iron Fountain
Kardoc
Level 3:
Top Expert:
  • Grilling Master 7,503 Answers
  • Posted on Mar 20, 2019
Kardoc
Grilling Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759691
Points
58323
Looks like Lowes use to sell it so maybe they will have a place to get parts.
https://www.lowes.com/pd/Garden-Treasures-Kingston-Fountain/3118463
1 Related Answer
kjhbwetrgwkj
Will
  • Posted on Nov 24, 2014
SOURCE: Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Miele W3740 Drum shaft spider - 3 arm - broken
It looks like it might be a UK Model. They are normally cast aluminium. You may be able to get it welded.. There are some parts suppliers in the links.
https://www.google.com/search?q=miele+w3740+drum+spider+replacement
https://www.google.com/search?q=miele+w3740+parts
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
What is the head bolt torque setting
Briggs and Stratton repair manuals are available at all location ware B&S parts are sold except lowes and Home Depot. I have one in my garage the cast iron motors are different then the aluminum ones I will need the model number for the exact torque spec 60000-130000 is 140 170000-280000 is 165 Aluminum and cast Iron is 190 IN.LBS. THIS IS ALL IN IN., LBS.,
I have a Viking Grill model VGBQ530 with cast iron burners that need replacement. I cannot find the exact model no. with these replacement burners however it appears that Viking now have a replacement made...
That is correct. Viking no longer supports the Cast Iron Burners. There is an aftermarket Burner VIKU1 that comes with mounting brackets to convert older Viking Grills that used a Cast Iron Burner to be able to switch to the stainless steel burner. The large bracket attaches to the center tube and has two screw holes and screws for mounting to the rear of the housing. The two smaller brackets mount to the two holes at the rear wall of the housing and create a ledge for the end of the two tubes to rest on.
1helpful
2answers
Bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
CGBD48RSBX Thermador, 9 yrs old, grates are rusty and flaky, Can I refurbish or need to replace. Still cooks pretty well!
if grates are cast iron they can be seasoned you have to remove flaky parts with putty knife brush real well and oil if anything other then cast iron youll have to order replacements
1helpful
Kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
54helpful
8answers
Apr 05, 2009 • Garden
Top Grilling Experts
Paul Carew
john h
Are you a Grilling Expert? Answer questions, earn points and help others
