SOURCE: lumix fz-20 panasonic has message
Does the camera start up as normal? Is the message intermittent? When does the message appear? (i.e. when zooming, when taking a picture, etc)
Unfortunately this message doesn't have one clear meaning. Or rather, it does - it says "something is wrong with the camera". From what I noticed with Lumix cameras, lens is usually the reason for this. (e.g. if there is a bit of dirt stuck in lens gears you would end up with the same message). If it's dirt in the lens, the solution isn't easy, you either need to have it repaired at panasonic service, get a replacement lens from an otherwise defective donor camera from e.g. ebay and replace it, or alternatively dismantle and clean the lens yourself if you're brave.
On one occassion I saw this message appear due to a problem with flash circuit. Disabling the flash sorted it out.
I would recommend first trying to disable any fancy options in the menu (e.g. flash, image stabiliser, macro, etc) and resetting the settings to factory state via the menu.
Good luck,
Raf
SOURCE: blue photos from a Panasonic Lumix DMC-TZ3 digital camera
It might be an idea to check whether your "white balance" is not set to "fluorescent light" or "custom white balance". "Auto" is the safest option here. Incorrect white balance would cause blue/yellow cast on the picture. Otherwise the problem might be more severe (i.e. sensor failure-not common in TZ3 though).
If you're still getting blue cast with white balance set to auto, you can try to set "custom white balance" with white sheet of paper (refer to the manual for details) - this will override auto white balance.
Raf
SOURCE: How do I set my Panasonic Lumix DMC-LZ2 Digital
You can set the megapixels and the quality but not the dpi. DPI is a setting for printers and scanners.
SOURCE: instructions for lumix digital camera dmc-fx10
You can download the manual from the support section of the Panasonic website.
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
