Video Game Consoles & Games Logo
P
Peggy Delauder Posted on Mar 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am not a repair person so please go slow. I have read fix repairs for 2 long 5 short flash error codes and there"s no back light to display service menu. what do I do now?
Chris Walker
Level 3:
Top Expert:
  • Light Master 1,573 Answers
  • Posted on Mar 20, 2019
Chris Walker
Light Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245586
Points
21965
5 Related Answers
Anonymous
  • 134 Answers
  • Posted on Oct 30, 2007
SOURCE: playstation 2 slim repair
There are a couple of things that you can try. The main issue is there is a problem with the laser, try to clean the lens of the drive.  If this does not work, then you laser is bad.  You'll have replacement with new laser.
Anonymous
  • 417 Answers
  • Posted on Jan 06, 2008
SOURCE: Ricoh Aficio fax 5000L (error code & Factory Settings?)
HI there below is the reason for your error message and it is to do with the laser unit and will normally need to be replaced when this message comes up.
Hexagonal mirror motor startup error 3-31
You could try resetting it by the following
· Try to clear the service call condition (for failures which are not related to the
fusing unit): switch the power off, wait 10 seconds, then switch back on.
I take it you have already tried this but if this doesn't work then the unit will need replacing
Thanks J
siggy7488
  • Posted on Jan 20, 2008
SOURCE: Service Call 17H
had this message 17H after unpacking the Magicolor 2300 W.
Here's the step by step way to fix it, done with the help of an online technician on the phone.
Cause : one of the toner cartridges was unproperly installed in factory, or went loose during transport, so the whole toner rack is out of synch.
Solution : manually take out and reinstall ALL cartridges and reboot.
Time : 10 mins
IMPORTANT 1 : turn off the printer and UNPLUG it as you need to "erase" the error from its memory.
IMPORTANT 2 : this is a manual intervention, byp*ssing the electronic-*ssisted way to replace cartridges. As such, there's a risk to damage the unit.
IT'S YOUR CALL :D
How (you need to use the printer parts'names in the small manual):
1. Take out the waste toner bottle.
2. Release the transfer unit release blue lever clockwise to upper position (11:00)
3. Pull out the OPC drum cartridge and hide it in a box away from ambiant light
4. Now the fun part....
5. The toner cartridges are to be pulled out through the oval hole in the upper left corner. PLACEMENT IS CRITICAL.
Chances are there's not a cartridge ready to be pulled out as the rack is out-synch, u probably see 2 cartridges through the hole.
You need to manually rotate the rack for each cartridge BUT YOU MUST ACTIVATE ITS FREE-WHEELING FOR THAT.
DON'T FORCE THE ROTATION, YOU CAN DAMAGE THE UNIT.
6. About 1 inch to the left of the hole, there is a tiny rectangular hole with a circle button inside.
Use a flat screwdriver to push this button about 1 inch inside and hold it there.
(You know you're doing well if you can rotate the rack with one finger, almost like a bike's wheel...)
Then you can manually rotate the rack and take out each cartridge. AGAIN PLACEMENT IS CRITICAL, DON'T TRY AND FORCE OUT THE CARTRIDGE.
7. Take out all 4 cartridges.
8. Put them all back again, make sure you respect the color code (ie. C cartdrige is C slot, etc.)
9. Put back OPC Drum, etc.
10. Plug the printer and restart it.
That worked for me, the blue cartridge was indeed loose, no more 17H.
Best regards,
Taipan
This message was edited by taipan on 6-3-05 @ 2:52 AM
Also read that you could try turning the machine on and hit the change toner button. If it lets you change toner, then remove all the toner cartridges and install them again and see if that clears it up.
ottoman23
  • Posted on Jun 12, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
ROD GANDY
  • 1602 Answers
  • Posted on Feb 13, 2009
SOURCE: Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
tip
Fix all your PS3 Problems
Send Your Console to Sony = $150
You need a PS3 Repair Guide = less than $35
THE NUMBER 1 GUIDE IS YLOD REPAIR WIZARD
This guide has proven permanent fixes for the following errors:
In order of the most common:
1.YLOD (Yellow light of death)
2.Green/Red/Blue Flashing errors
3.Disk Read Error/Blue ray Drive Error
4.Hard Disk Corruption
5.No Display Error
6.Red Screen Error
7.Freeze ups
8.Fix All error codes (8001050F)
9.Sync error
10.Blank Screen error
Need More Info On PS3 Repair guides and the YLOD repair wizard
3helpful
2answers
Engin light stays on
The ECM has detected a fault in one or more of its systems. Go here,
extreme-check-engine-light-codes.com
and it will explain what to do to extract any codes that are stored.
Come back here with the code(s) and I can try and help further.
33helpful
2answers
Flashing red light and ps3 will not turn on
hey there you have the red light of death
When your Experiencing Problems with the PS3 like this you mainly have 2 options to take, I will go through each one now so you know what to do.
Option 1
Send The PS3 to Sony
Almost all problems with the PS3 Sony can fix easily if not they will send you a refurbished model.
Price:
If your in warranty they will not charge you for this repair/replace.
If your out of warranty the Charge will be $150
Waiting Time:
4-6 weeks
Sony Contacts right here
Option 2
The PS3 Repair guide
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems found below:
NOW THE PROBLEMS BELOW CAN BE FIXED WITHOUT OPENING YOUR PS3
PS3 Yellow light of death fix
The YLOD - Yellow light of death
The Red light of death
PS3 Freeze up Error
More Technical Problems Below
The Hard disk Corruption error
The Red Screen of death - Serious error
The Disk Read error
PS3 No Signal Error - no display
FIX All error messages
But not everyone knows they can fix simple settings problems like all error messages and the no display error, av and hdmi screen problems and more.
Price: averages between $30 - $40
Wait time: instant download and repair within 2 hours
I really hope I have enlightened you and you do what is needed to fix your problems with the PS3 and get back to gaming soon as possible
Please leave any comments if you need any further assistance
Best Regards
Peter Fix
Cords got ripped out of system then i plugged it in and its blinking then flashing yellow and turning off
Welcome to Fixya
YLOD or yellow light of death (indicated by the flashing yellow light). When you are Experiencing Problems with the PS3 like this you mainly have 2 options to take.
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
When your suffering problems with the PS3 its often easy enough to fix it at home with a good ps3 repair guide. There famous for fixing major problems like:
The YLOD - Yellow light of death/ Red light error
The Disk Read error
PS3 Freeze up Error
Price: averages between $40 - $60
I really hope I provided you information to fix your problems with the PS3 and get back to gaming soon as possible.
Thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How do i get the game out of my ps3 when it flashes yellow and how do i fix it?
Welcome to Fixya
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
The Disk Read error
PS3 Freeze up Error
Cheers!
23helpful
When I switch my PS3 on the green light comes on then goes off and is replaced by a yellow light before returning to a flashing red light.
hey there you have the yellow light of death
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
PS3 Freeze up Error
The Disk Read error
Best Regards
Peter Fix
I think it called yellow death lite
Welcome to Fixya
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
The Disk Read error
PS3 Freeze up Error
Thank you!
Briefly turns on beeps flashes yellow and turns off
Welcome to Fixya
Option 1
Price:
Waiting Time:
4-6 weeks
Option 2
The Disk Read error
PS3 Freeze up Error
Thanks!
Top Light Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Light Video Game Console and Game Expert? Answer questions, earn points and help others
