Refrigerators Logo
Karyn Wright Posted on Mar 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there, I have a Samsung fridge for about 10 years now and after I moved last year it started making an obnoxious sound when the door is closed. What could that sound be ?
Chris Walker
Level 3:
Top Expert:
  • Samsung Master 1,573 Answers
  • Posted on Mar 20, 2019
Chris Walker
Samsung Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244319
Points
21965
Compressor.
Testimonial: "Thank you."
5 Related Answers
Anonymous
  • 958 Answers
  • Posted on Feb 12, 2008
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Anonymous
  • 1314 Answers
  • Posted on Mar 28, 2008
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
BNewberry
Bill Newberry
  • 93 Answers
  • Posted on May 15, 2008
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
santange
  • 99 Answers
  • Posted on Jan 31, 2010
SOURCE: loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
espressonist
espressonist
  • 1711 Answers
  • Posted on Sep 15, 2010
SOURCE: My fridge makes a whistling sound after I have
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
Hi there my merlon garage door lifer will not lift the garage door , the motor is running but the belt is not moving , can you help me with this ? Thanks chris
It's probably a stripped gear caused from an unbalanced door. The door itself has springs to counterbalance the weight. Depending upon how many cycles your door goes through in a day will determine how long they'll last. Springs SHOULD Last You Between 5 To 10 years. Sounds like u need work. OR....the opener is disengaged from the door. Pull cord for black outs. Good luck.
1helpful
Samsung refrigerator dispenser makes noise after filling water glass
You may need to have the water filter replaced. This sounds like it is starving for water as it refills.
5helpful
We own a RF267AARS/XXA refrigerator. Ice maker works slow. Hardly ever makes a full tray of ice in 24 hrs. Then for no reason quits making ice for 2-3 days. I the pull the ice-tray out a couple of times...
You'll have to read my in depth review on Epinions.com for answers. Sounds like you bought the updated version that over corrects the "too much" ice which jams the mechanism to where it breaks the unit. This is my second friggen Samsung as my 1st 4 door quatro was replaced under their lemon law. Spending $2500 I thought I was buying quaility, instead I bought greif. I'm still working with Best Buy to get Samsung to fix the icemaker with it's current problem which sounds like yours. Go to the Epinions website and look me up, my username is "walkerpkw" My review was posted last year. Read both my horrifying Samsung reviews. Something is very wrong with their engineering department. You'll find my email address on my profile page. I'd be happy to inform you if the get this fixed. I'm told it's the fridges computer board and they're redisigning another?
Hi I have had a double door fridge freezer for over 3 years now ,it has now starting making a noise for what i can only think is a fan.Could you tell me if snd how i can fix this problem?
Greetings..
Fan in freezer usually make noise after a couple of years and it is common problem to every freezer. Either you replace it with new fan or have it fixed with a technician.
Thanks.
Hi, i have an Bosch just over a year old and it has just recently started making a noise from the back of the unit. It sounds like a fan rubbing or rattling, it stops as soon as the fridge door is opened.
hi thanks for the question .It sounds like the fan in the fridge is rubbing locate the fan and clean out the obstacle thanks the appliance doc
Funny smell from RS2630SH
Dear friend,
ngfam at you service! happy to assist!
Whirlpool sells odor stoppers for your fridge!
And keep a open box of baking soda on the door always!
HERE IS THE WHIRLPOOL SITE BELOW
http://www.whirlpool.com/catalog/
accessory_category.jsp?parentCategoryId=
323&categoryId=370
How old is the appliance ?
If it's 10 years old or more it's not worth sinking good money into bad !Todays appliances are so much more efficient that you save money on you electric bill!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
hi
this refrigerator having problem related with defrost cycle.fridge is able to defrost after period.please check it as follows
there is timer box located behind the fridge near to compressor with white color knob.attach the clamp meter on one wire of main cord,check current drawn by fridge when comp.is running.turn the timer knob clockwise to hear big tick sound where the comp.will stop,check the current in meter which should be 0.6amp.if it is not showing then there is problem with bimetal or heater which is inside the frizer
Thanks,
Bill
Freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
