SOURCE: Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
SOURCE: error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
E061
Main Cause The laser shutter is
faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller
PCB is faulty.
Mode of
Detection
0001 As the result of potential
control, the drum surface potential (VL2)
of the white background is about
200 V (generating solid black images).
0002 The primary charging output
used for print output and the drum
surface
potential after laser output has been made are about 200 V
SOURCE: XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO
H4Fuser temperature too low. Must be reset in diagnostics
