SOURCE: DOOR CATCH BROKEN - HOW TO OPEN DOOR FROM INSIDE THE MACHINE
Select washing machine at link below to find door handle
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
SOURCE: door won't open
Check your instruction manual to see if there is a childlock feature that has been activated.
Is there water in the machine or has it completely rinsed out?
If you switch the power off and wait a couple of minutes, can you then open the door with the power still off?
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
