I have water in my carborater now its not running well
First drain the fuel tank , fuel lines and drain the oil while its draining , put a fan on the wiring and dry it out. Take the plugs out of the engine and turn the motor over this will force any water that's left in the cylinder out .Water that's got in to anyother parts of the engine will come out with oil Add oil to the engine and turn it over again ,without the plugs in .Let it sit for 5 minutes .then check the oil to see if there's water in it ( If there is it will look like a white milky substance ) if there is u need to drain it and start all over again u will have to keep doin this untill there is no white in the oil . Now once u have done this re-install spark plug,add the gas , then try to re start . If it starts. Leave it to run for a good few mins BUT don't rev it .
After it runs for a few mins turn it off re-drain the oil and change the filter .run again for few mins, turn off check the oil again for. A milky colour if there's none yippy uv done it if it dosent start u need professional help good luck
