How to Change the Language Settings on the Dell V305/V305W...
https://www.dell.com/support/article/au/en/aubsd1/sln122992/how-to-change-the-language-settings-on-the-dell-v305-v305w-printer
SOURCE: Printer Dell Photo All-in-One Printer 926 language
Here's an effective way to change the language on the 926 printer *turn on the printer *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key four (4) times *press the check button *press the right ( > ) arrow key three (3) times *press the check button *press the right ( > ) arrow key until you find "English" *press the check button let me know if it works thanks!
SOURCE: sandisk sansa fuze in foreign language need to change to english
turn on your sansa fuze then press the menu button then go to the picture of settings then go to the very bottom of the list and press the center button then go down 5 slots and at the very top it should say english and press that one or find someone that speaks the language and have him or her fix it
SOURCE: I need to change the language settings on my
Press the * and # button together and release them. the display will now show '**************#########'. now press the 1, 2, and 3 buttons one after the other. Then it'll show 'Support' and the firmware version. Next press the Right arrow button twice so you see 'Resets Menu'. Press the OK button. Press the OK button again when it shows 'Country/Language Reset'. The printer will now shut down. Turn it on again, and you can select the correct language and country.
SOURCE: Would like to change Language
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
SOURCE: My dell v313w printer gives
Are you using Dell Series 21,22 ink cartridges?
Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
If you unplug the printer from the wall and remove the power brick for 60
seconds, this will reset any error messages the printer has. I would then plug
everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 21, 22 black
cartridge and then reseat it. I would then take out the color Dell Series 21,
22 ink cartridge and reseat it. Now close the printer and it will print an
alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color
side(right side)
photo cartridge = black side(left side) color cartridge = color
side(right side)
Dell Series 21, 22 ink cartridges have a sensor in
them that cannot be reset. Article on refilling Dell ink
cartridges.
Dell Series 21. 22 ink cartridges can be purchased
at Staples, Walmart or Dell's
Website.
It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I
would take these back to the place of purchase for a replacement or a
refund.
Rick
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
