Question about Watches
Enghstadler battery operated cuckoo clock stopped cuckoing cucko comes out but does not cuckooas pendulum does not swing. hour and minute hands are not moving. batteries replaced same problem
SOURCE:
  • 2501 Answers
SOURCE: Bergen Enkheim Clock won't stop chiming. The
It sounds as though part of the mechanism that controls the chiming is jammed. This could be caused by dirt or wear.
I suggest you have the clock cleaned as a first step and ask if there is any sign of damage.
Posted on Jan 06, 2010
Testimonial: "Thank you very much for the advice *. ~"
cmcduncand
  • 714 Answers
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Posted on Jan 21, 2010
cmcduncand
  • 714 Answers
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
Posted on Feb 15, 2010
  • 8404 Answers
SOURCE: i just got a Bradford
I am not familiar with the product you have. However, if this is a genuine cuckoo clock, driven by weights, the weights must be "wound", weights pulled to the top of their travel. If this is electronic, I would be looking for a switch. There also may be a electronic eye that prevents the sound at night. Can the eye see the light?
If you just got it, and if my comments don't apply, I am sure a quick call to the Bradford Exchange will solve your trouble, whether it is a step you inadvertently over looked or if the device if fault. I am certain they will help you.
Thanks for your question @ FixYa.com
Posted on Feb 17, 2011
aquaman987
  • 927 Answers
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
Posted on May 29, 2011
I have a 2 weight cuckoo clock.the weights are stuck at the top of the chains and the pendulum doesn't swing...help, please.
Probably needs cleaning, but you can try removing the pendulum altogether. Time will fly but the chains will drop. One weight runs the time and the hands, and the other makes the cuckoo work. If it is a good clock, have it professionally cleaned.
see videos
https://www.google.com/search?safe=off&client=firefox-b&ei=M1FvW_2UE4TWjwTqv6D4DA&q=cleaning+cuckoo+clock+movement
Aug 11, 2018 | The Watches
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Aug 04, 2010 | Watches
I do not know how to start the clock : Clock under glass. Has three balls supposed to swing. I replaced the battery.
Lift the glass and swing the pendulum/balls. Or you could, if it's small enough to hold in your hand, suddenly twist it, there by using inertia to swing the pendulum.
Aug 03, 2010 | Watches
I have a forestville wall clock with the pull down weights. when it chimes it is behind in time. example nine oclock chimes seven oclock, it is a made in germany clock but what year i do not know. there...
Stop the pendulum of the clock exactly at any even hour. Lets say at 6.00. While clock is steady and not working, pull off the minute and hour hands off the pinion, but do not brake them. You have to pull without any twisting action. This will leave pinions exactly in place they were when you stopped the clock. When it is done - push the hour hand back onto the pinion and make sure it is pointing at 4 (not 6, as it was when you stopped the clock). When hour hand is back in place and pointing at 4, push back minute hand as it was when you pulled it off - pointing at 12. Make sure hands will not catch when passing each other (you can bend them slightly if needed). Now swing pendulum to start the clock and adjust time (clockwise only). Never adjust time when clock is chiming. Rate me, plz.
Feb 02, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Nov 02, 2008 | Watches
Watches Logo
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
