We removed the front panel and the water comes out of the counter weight from behind. There are no visible tears on the boot/seal at all.
SOURCE: whirlpool duet washer seal leaking
It is recommended that you replace the rubber seal rather than try to repair it. It is not a difficult repair and the rubber seal generally runs about $80. Most appliance repair places will charge more for the part, plus a labor charge. The result could be a repair bill of over $200. If you would like to attempt the repair yourself, here's how:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will dettach from the tub.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. Sometimes the tube is not inserted all way into the boot and water will leak behind it. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Then, beginning at the top start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be adviseable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful. Let me know if you have any further/questions and concerns. Good Luck to you.
SOURCE: WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified.
SOURCE: whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you.
NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
SOURCE: Whirlpool duet Sport wfw8300sw02, is a piece of
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
