SOURCE: Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
SOURCE: Royal rs9512c shredder
call royal spare parts department at 1800-222-2310 they will ship you a gear for about $6 + shipping
it will stop the clunking
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
SOURCE: Shredder motor runs but won't shred paper. No
If the motor is running do the cutting shafts turn??? if not then unplug and open up the top to see if any gears are broken/stripped; give Royal a call at 1-800-524-0799 for parts and prices once you've located the problem.
SOURCE: Paper has collected around the shredder blades. I
Remove the cutting head...remove the top plastic cover to gain access to the inside...clear paper from inside and reassemble.
