SOURCE: DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
SOURCE: How do I clean the rollers on a canon DR-3080CII
Lightly dampen a cloth with water or rubbing alcohol. Gently rub across the roller side-to-side, rotate a little, and continue until you've gone all the way around. The most important rollers are the 3 at the paper feeding area (2 top & 1 bottom). The bottom roller will be harder to turn than the top 2. Just be gentle & patient to avoid tearing the rubber. Frequent light cleanings are better than waiting for problems to crop up.
SOURCE: I have a Canon DR-3080CII scanner that is making a lot of noise.
If you haven't had problems then they are probably fine. The feed rollers are rated for 500K pages, and usually last at least half that even under severe duty. Regular light cleanings by the operator are recommended. Once a year a service tech should do a more thorough cleaning of the transport rollers & sensors. When the rollers do wear out, you can purchase them from online retailers like ScannerSolutions.com, but they aren't designed for easy user installation. Call your local dealer for a quote; the extra expense is worth the saved effort, and they should do a complete cleaning at the same time.
