Building Materials Logo
Karen Wert Schultz Posted on Mar 18, 2019
Chamberlin whisper drive model 248754 has a broken spring. Can I repair this myself?
Sean Devoy
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Mar 19, 2019
Sean Devoy
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
10790
Points
81
What kind of spring? The big spring(s) that help lift the door or an internal part?
Additional Info:
The part is cheap and not too hard to install:
https://www.chamberlain.com/search/?text=41B4103 It just screws on the end of the chain where it meets the slide assembly.
Testimonial: "The big spring - the torsion spring. I looked into it and it sounds like it's best to have it replaced and installed as it's not easy to do yourself. Thanks for the response"
5 Related Answers
Anonymous
  • 244 Answers
  • Posted on Jan 17, 2009
SOURCE: chamberlin whisper drive 3800
may be bad logic board. is trolley jammed?
Anonymous
  • Posted on Aug 23, 2009
SOURCE: Red LED light remains on and beep sound
My battery is bad. I knew it, but did not feel like it was worth any of my attention. The beeping started yesterday and this was worth my attention. Everyone in the family complained. I suspected it was the battery.
I unplugged the unit. Disconnected the battery. Waited for 30 seconds. Plugged it back in. It works fine and no beeping.
I suspect it is a warning to replace the battery.
Anonymous
  • 3197 Answers
  • Posted on Nov 11, 2009
SOURCE: I have a chamberlin whisper garage door opener and
Your first step is to find out if it is the opener or the door. Then you should be able to isolate the squeek.
Anonymous
  • Posted on Jul 02, 2010
SOURCE: we have installed a chamberlain wireless keyless
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
Anonymous
  • 1654 Answers
  • Posted on Jul 03, 2011
SOURCE: I have a chamberlain (whisper
That is the warning alarm to tell you that your battery isw about dead,.Once you replace this it should clear up. If you want to unplug the unit, disconnect the battery and wait 30 sec and plug it back in, this should also stop the beeping.
Premium Chamberlain garage access systms feature an internal battery backup that will operate the opener in case of a power outage. The garage door opener will emit a beeping sound when it is operating off of battery power or when the battery is no longer able to recharge. A fully charged battery will provide power to the garage door opener for 1 to 2 days of normal operation when power is lost, and when power is restored will recharge within 48 hours. While the garage door opner is operating using battery backup power the light bulbs will not turn on to conserve battery power.
NOTE: To obtain maximum battery life and prevent damage, always disconnect the battery if you unplug the garage door opener while on vacation or any other extended period of time.
My Chamberlin whisper drive garage opener tries to open on left side of door but right side won't move
Disconsolate door from opener at trolls ( pull red rope[e down and see if the the moves freely and easily If you have torsion springs look at them it may be broke of have come loose. This is not job for DIY. The springs are under tremendous tension, and loosen them or trying to wind them will send you to the hospital or morgue. If the door hase 2 springs attached to holders at back of door may have broke or come lose.
2answers
When i change my drive belt it gets shreded on start up
Sounds like either the belt is not tight or more likely your door balance is heavy ie fatigued/broken springs or its hung up somewhere.
8helpful
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
I have a chamberlin whisper garage door opener and it is sqeaky now........how do you make quiet again? Thanks
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Installed Chamberlain Whisper Drive but door slides backwards
It sounds like you may have a spring problem. Release the door from the opener and see how it acts manually. Open it as far as the opener does and then see what happens when you release it. Also the weight of the door should give you a clue.
27helpful
3answers
1helpful
Chamberlin whisper drive 3800
Top Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Building Material Expert? Answer questions, earn points and help others
