What should I do to fix problem
SOURCE: driver window will roll down but the passenger and rear wont
The first thing that I would do is check for electricty at the motors them sel and work your way back.If there is elec. at the window motor it's self susspect a motor problem.Remove the motor to see if it spins (but it dosen't me its good it could be week)next check for binding in the window mecanism.
SOURCE: passenger window wont go down but can hear motor working
You need to replace the regulator inside the door. It's the little pulley system that will pull your window up and down when you push the button.
Takes about 20 minutes to fix, so you're looking at about 100.00 at the garage.
SOURCE: passenger side power window wont roll up
The problem may be in the wiring which if you pull up the carpet on the front passenger side by
removing the door floor trim and lifting the carpet you will see the
wiring underneath. Probably laying in water or has been. Look for splices in the
wiring which will have corroded. Repair the wiring then check the fuse.
Another problem may be in the motor found inside the door.
The brushes may have worn out. If so you need to replace the motor.
Ususally the drivers side will fail first since it is the most used.
SOURCE: 1999 Dodge Durango driver side window does not roll up nor down.
Remove the door panel and find the window motor Unplug it and using a separate car battery run cables directly to the window motor When you switch the polarity the motor will either bring the window up or down or if noting happened change the window motor and window regulator assembly.
