Question about The Audio Players & Recorders
Onn 37" bluetooth soundbar not working with t.v. apps. Works with direct t.v. plugged optical into t.v. and soudndbar, but none of the apps produce sound. Changed t.v. setting to pcm. Still nothing
SOURCE:
SOURCE: No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Posted on Jan 08, 2008
SOURCE: Z-680 optical acting very strange
I bought a new cable. The old one was bad.
Posted on Mar 19, 2008
  • 73 Answers
SOURCE: Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
Posted on Jan 21, 2010
benwabnick
  • 2404 Answers
SOURCE: The mouse has lost its air feature. Still works
Sounds like the bearing went bad on the fan. If you could take apart the mouse, I would suggest using WD-40 on the fan to possibly loosen up the bearings.
If that doesn't work then for sure the mouse is bad and would need to be replaced.
Posted on Feb 05, 2010
  • 71 Answers
SOURCE: I just bought the Vizio
Make sure its all hooked up right two wires switched could throw off the speakers
Posted on Nov 06, 2010
Trying to install onn 37" wireless 2.0 Channel Soundbar to Emerson tv modle LF401EM5. Multiple problems!
The onn cannot be connected to the Emerson wirelessly.
If it is connected to the Emerson TV, there has to be a wire plugged in to the audio output on the TV and the left and right input connectors on the sound bar. I have heard that you will only get about as much sound from the sound bar as the TV.
You cannot use the digital audio outputs.
Sep 11, 2018 | Emerson Televison & Video
Onn soundbar will not work with Emerson flat screen tv. What am I doing wrong? hooked cables up red to red and white to white and plugged in power. Turned tv internal speakers to off. no sound
Some TVs produce no audio output with internal speakers turned off. A convenience for headphone users; an inconvenience for soundbar users.
Aug 03, 2018 | Emerson Televison & Video
I have a Samsung soundbar connected to my TV. Sound is working fine through the optical cable. But when I connect the soundbar to Bluetooth there is no sound at all. Please help.
Try pressing and holding the Bluetooth button on the sound bar, that will put it in search mode. Once it detects the Bluetooth device it will connect.
Feb 10, 2016 | Samsung Televison & Video
I need a power supply cord for soundbar #psb3713-b
I could not find one anywhere. I finally tried the power cord from my Craig soundbar model# CHT923 and it works fine. It is probably easier to find this power adapter.
Mar 11, 2015 | Proscan PSB3713 37-Inch Bluetooth Sound...
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
How do i connect a technika TKSBSE213 soundbar to a telly
Does your TV have a Digital optical port? It's a cable that sends a red light source. That is actually how you're suppose to hook up a soundbar. digital optical cable Bing images Straight forward. Plug and play. If you're TV doesn't have an optical port, as I know your soundbar does then you have to use a stereo Y Cable. 3.5mm to Red/White. Sound bar will have 33% the power going this way as opposed to an optical cable. Aux Audio Out has a itty bitty amp pushing power. Purpose of the Digital optical Cable is a light source.
Jan 18, 2015 | Audio Players & Recorders
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Do i need to buy anything extra for my ilive 37' soundbar for my tv? The sound doesnt work with my tv, but the bluetooth works just fine.
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
Nov 28, 2014 | iLive 2.1 Channel Sound Bar ITP152B
Unable to use lg42pq3000 with lg soundbar
You have to direct the audio out on the tv to the optical output in the setup menu
Jan 01, 2014 | LG 42PQ3000 42" HDTV Plasma TV
Trouble setting up sony soundbar surround sound, is tv arc compatable?
Arc ready is when there is electricity plugged into the TV,There is only one HDMI cable and that is the one you have. Cause all new TV's come with these cables.If you are using Av cables for the sound it will not work ,you must only use HDMI cable's.Cause some or most new TV's with HDMI dont like to use Av cables with HDMI,so if you havw something else that uses Av cables plug it out and sound will work.
Dec 28, 2013 | Proscan 47LC55S240V87 47 LCD TV
51 people viewed this question
Top The Audio Players & Recorders Experts
meowwl
Level 1 Expert
D. E. Hev
Martin van der...
Martin van der...
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
