Question about Frigidaire Dryers
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes
My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
SOURCE:
SOURCE: Machine runs, but clothing won't dry
It sounds like your heating element is shot. The elements on this machine are very sensitive and if you use too much cleaning fluid the part will wear down after a while. You will need to get the part replaced (yuck) and start to use a little less washer fluid. Please let me know about your experience with the company (danfrogel@yahoo.com)
Posted on Sep 25, 2006
  • 291 Answers
SOURCE: Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Posted on Nov 23, 2008
  • 99 Answers
SOURCE: Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Posted on Feb 07, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Posted on Feb 09, 2009
  • 401 Answers
SOURCE: Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 16, 2010
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
Just got electric dryer #FAQE7011LW0 dryer will not heat manual says check fuses but does not say where they are located
The fuse they are refering to is the fuse/circuit breaker for your house wiring in your house fuse box/breaker panel
Sep 18, 2011 | Frigidaire Dryers
Dryers Logo
69 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
