I havent used this machine for a few years but I cant wind the thread onto the bobbin! I have the one page instructions for it but its just not working, it winds for a few seconds then stops and beeps
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
SOURCE: Bernina 180 - winding thread onto bobbin spool
Also it is quite possible that the small circuit board (P-print) just below the bobbinwinder that the motor plugs into has gone bad.
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
SOURCE: Bobbin Winding problem
Pass the bitter end of the thread from the inside of the bobbin and up through the hole or slot in the bobbin to the top. Hold on to the thread as it turns to get it going.
SOURCE: Winding the Bobbin
I have the same problem and was skeptical of the drop of oil solution but it worked. I had taken my baby lock ellure apart while investigating previously and found nothing else wrong. Tried a few drops of oil and after a moment it started winding noisily and then settled right in!! Working perfectly now!
