Cross-reference to this is Intermatic ODT-309 or DT-309
See if this gets you anywhere:
https://www.manualslib.com/manual/970929/Intermatic-Dt300-Series.html
SOURCE: Need user instructions for a Grasslin iht d120
Took a little hunting but managed to find it for you.
Here's the link to the manual including programming instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/km2st-2d%20-%20english.ashx
Have a great day
Jim
SOURCE: Re: Westinghouse Wall Oven/Grill .Timer
Hi, well i tell you these units are a pain to get into the area where the wiring hooks onto the module... also there were a few variants, so the timer modules were different, this means one would have to have a service manual of the exact make model to even be able to source the bits, in the first place. This is the BIG problem, obtaining the exact parts.
My recommendation is to save yourself skinned knuckles and time and money, and call an an electrician for that "Quote'.
SOURCE: I need operating instructions for a wylex timer
There is no instruction manual for Wylex timers.
However the Wylex sell sheet appears to show generic din rail mounted timers.
Since these timers are made by other companies, and then sold by various companies, and then the models change rapidly, the best course of action is as follows:
1) Re-post question with clear and detailed description of timer buttons, and say what the timer controls.
2) Google image search for 1 and 2 channel timers to find same-similar timer.
3) Most timers have similar programming steps and once you find timer with same buttons, then that timer manual can be used to program unidentified timer.
4) Open following links to find din-rail timers that might match:
http://waterheatertimer.org/Hagar-timers-and-manuals.html
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DIN
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: where are pins on smart electrician 24 hr timer
1) Copy following link for setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
2) Copy following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
3) Add comment and describe timer in detail
