Will not connect to internet
SOURCE: Internet Light keeps blinking - all others are out - No internet
A flashing internet light(all others off) indicates that the modem is searching for a signal from your ISP. Try rebooting the modem and if that doesnt do it replace the coax going to the modem. If you still dont have internet then go ahead and call your ISP as it could be a problem on their end.
@CluelessNYC: If you purchased a modem from a third party then you may need to register the MAC address with your ISP. Most cable providers tie your account to a specific MAC.
http://www.simplehelp.net/2006/08/01/cable-modem-troubleshooting-rca-dcm325/
SOURCE: Internet Not Working. Light on box blinks red then green. Gateway
that means the box needs to be reset if its going red like that its glitching if the reset doesn't work then something is wrong and i would get it replaced hope this helps
SOURCE: seagate external hard drive green light blinking
that problem means that it is acsessing the files on it. it is not a worry for you.
SOURCE: i have had problems connecting to internet all
hi, it depends on the type of the modem that you have, ethernet is for the connection of your PC to modem so it is normally green and blinking depending on the activity, but should always be on, internet light should be green also, blinking to steady which indicates that you are connected to the internet, DSL light must always be steady, otherwise you have to check first your telephone wire, perform power recycle, then call your ISP if still the same, if DSL is sync but internet light red/off, the settings of the modem might have been change, then, you have to call your internet service provider.
