Televison & Video Logo
HARRY COLBERT Posted on Mar 17, 2019
I NEED A CORD FOR MY HC318XW CLIPPPER. WHERE CAN I GET ONE
I need replacement power cord
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Clippper just stopped working
Check for spark. You can also spray some carb cleaner into the engine through the carb and if it runs for a second then it's a carb issue (not getting fuel).
My cousin said i dont need a cord to hook up to the enternet do i need a cord?
If your device is Wi-Fi enabled, then you don't need a cord. Otherwise, you will need a cord.
I just purchased my fryer at garage sale today, it's missing the cord. What type do I need to get and where can I find it. Thank you,
Hi and welcome to FixYa, I am Kelly.
These cords (unless the magnetic type are available at most hardware stores ("Woods" / Woods Industries or Coleman Cable are the product brand names.) These cords are usually in the area of extension cords.
Having said that... The distance between the pins is the difference. There are 1/2" cords 11/16" plug cords and 1 1/16" cords. I need to know the distance between the pins center to center of your fryer connector terminals.
Most Fryers use a 3 Ft cord and roasters use a 6 ft Cord. You cna use a 6 ft cord but do NOT use it for an extended period. The cord you purchase must be wire gage 16/2 NOT 18/2 in wire size.
The 18/2 gage will only handle 1250 watts.
The part number of the cord will be either 0290 or 09326 (You can net "IMAGE search" these for sources)
Here is one source for the cord.
http://www.hardwareandtools.com/Coleman-Cable-0290-6-Foot-Black-Appliance-Cord-0429928.html
If you have the magnetic base / end plug let me know and I will find you the correct plug.
Just repsond here and say you need the magnetic recepticle cord.
Thanks for choosing FixYa,
Kelly
CONAIR MODEL HC318 HAIR TRIMMER WORKS WHEN PLUGED INTO RECEPTACLE, BUT WILL NOT RUN ON BATTERY POWER. I JUST BOUGHT THE KIT AT WALMART, TRIED CHARGING BATTERY FOR 24 HOURS, BUT WILL NOT RUN ON...
If you purchased it recently and if you have the receipt and if you saved all the original parts it came with I would certainly return it.
Lithium batteries do need to be charged 24 hours at the very first opening of the box, but if you did that then just take the item back to WalMart.
Need power cord
You can get the power cord from any electronic or computer store near you or you can also get a second hand power cord from EBAY....
1helpful
I need a new power cord. I took out the back and
The power cord (E901 which plugs into P901) Hitachi part # for this model is EV00851 but it would not be commonly stocked since most repair shops would repair the cord. The repair would be done by either splicing a new cord on to the old one or unsoldering the old cords plug receptical (P901) and installing a new generic cord in its place - either way observe the polarity -white wire to thick blade of cord. Post back if you need more info (I may have a used cord)
Need replacement cord for rival CF153-WM
check out aelectric dryer or stove for cord or a replacement
1helpful
2answers
Can't find the parts I need
Hey, not sure if you still need it, but there's a power cord for the PDM-2727 listed in an Ebay auction. Like you, I need the AV cord, er, at least I think that's the problem. The listing also shows an AV cord available for an extra $5 but it looks generic. Might be compatible though. I don't need the power cord or I'd ask the seller, but you might want to check it out if you still haven't found power cord/AV cable yet.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
