Car Audio & Video Logo
S
Sean Posted on Mar 17, 2019
My Optimus cd-7200 6cd changer won't play. Just cycles through the discs. Any ideas? Sean
Eng.Hamdi
Level 1:
Habit-Forming:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 19, 2019
Eng.Hamdi
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
17
Questions
0
Helped
10847
Points
39
Clean laser glass inside
Testimonial: "I will try that, I hope it is easy to get to. Thanks! Sean"
5 Related Answers
Anonymous
  • Posted on Jun 28, 2008
SOURCE: My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Anonymous
  • 199 Answers
  • Posted on Jul 21, 2008
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
freetek
Steve Allison
  • 5569 Answers
  • Posted on Oct 28, 2008
SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Anonymous
  • Posted on Dec 01, 2008
SOURCE: 2003 Lexus RX300 cd changer will not read or play
Ha! I read the directions! The discs are supposed to be upside down! Problem solved :)
Anonymous
  • Posted on Dec 20, 2008
SOURCE: 1992 6 disc cd changer not working
Are you placeing cds face up or face down in the changer, some cd changers will only play with the cds face down.
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
1helpful
Cd changer shuffles but won't play
Check its laser pickup assembly for any dirt or dust. Click here for more details
Cds skip. when inspect the cds , there are smudges on them after they have been played. It looks like it is in the same area as the magazine changer pads. Do I need to replace the magazine? PS it apears...
Dear donahuecontr,
Welcome to fixya support,
It is deffinately due to magzine and magzine wheel.So replace it with new one it will solve your problem.
I think it helps.Let me know.
2helpful
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
1helpful
Rosen Dva3210 10-disc cd/dvd
You need to tune to the same FM frequency selected on the RFmodulator box e.g 87.5 MHz to listen to whatever is playing. Good luck. Do you know a website to down load the mannual?
RE-TIMING OF DECK MECHANISM
Hi there a pain, the 3 black gears/guides on the 3 poles slip there is a mod kit see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
works in 9 out of 10 cases.
Regards
Mark
Pioneer CDX_1280 12 Disc Changer
hi sounds like dirty laser, or dodgy disc.
check your cd for marks. you could try a cd cleaner disc. this may cause it
other wise its a new laser
Mark
Blue ICE
www.blueice-electronics.co.uk
Error message E08
You said you cleaned the player but did you clean the disc? Any scratches, dirt debris? To clean the disc you can but special cleaning soultions at various retailers. Have you tried playing diffrent discs, that will help rule out if it's the player or disc.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
