I think that the black is the important one, so it can`t working without it.
you can back to printer manual to check if it will be working without other inks or not (if your printer have 2 cartridge one for black & the other one for three colors as one cartridge, it almost can working with black only).
if you write the printer model it can help more
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
SOURCE: MFC-240 shows no ink cartridge
Same problem here... Figured out something that works fine for me anyway.
I took some black electrical tape and covered the clear plastic area in the front of the cartridge. It's a bit of a delicate procedure. Need a piece of tape about 3/16 of an inch wide and 1/2 inch long to match the contour of the clear plastic so it still fits inside the printer and can be surrounded by the light sensors.
Unfortunately, I think Brother is making too much on the ink cartridges and therefore is trying to make them tamper proof. I t's backfiring on them. Will never buy another Brother.
SOURCE: Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
SOURCE: Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Sometimes the ink cartridge carrier won't automatically
move to its loading position even when the printer is on and the cover is open.
Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that
connects from the carrier assembly to the ink cartridge carrier and gently
slide the cartridge carrier to the center of the printer.
3. Remove the used
cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
