Question about Polaroid Audio Players & Recorders
I have a Polaroid 3022 speaker the vokume is too loud for my firestick...how can control the volume?
SOURCE:
  • 63 Answers
SOURCE: Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Posted on Aug 09, 2007
yeokeke
  • 5 Answers
SOURCE: Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Posted on Nov 24, 2007
otacon
  • 1950 Answers
SOURCE: Bose amp
Here is the manual.
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
Posted on May 29, 2009
MalKontent68
  • 748 Answers
SOURCE: Older Harman Kardon computer speakers have loud hum
Most probably it's an internal problem with their power supply (a capacitor with broken soldering).
It can be quite easily repaired by a person knowing which side of a soldering iron to grip ;) If you have a friend that's familiar with electronics, you can ask to take a look. If you don't, the repair shop will most probably want a flat charge, which will not be feasible.
Posted on Nov 28, 2009
Sub Speaker giving intermittent loud crackling and sharp loud popping sounds even with main volume control turned off. Crackling sound can be reduced by turning sub volume control off.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Mar 17, 2016 | Altec Lansing Acs295 Subwoofer
I have a Sony tv that I have my new firestick attached to currently. But my xfinity x-1 box is plugged into my marantz system where my speakers are connected and controlled.
You should have an optical audio output jack on your tv that you can connect to your receiver to output audio through your speaker system.
Dec 26, 2015 | Sony Audio Players & Recorders
How to set up
these speakers are easy to setup. The two speakers are already connected to each other, and the out cable comes from the speaker with the power and volume. The subwoofer and power also connects to that speaker. you would liked to have had the second speaker have the ability to totally disconnect from the main speaker, and you would also have liked to have had a headphone jack built into one of the speakers. Besides that, these are very easy to use, press power, turn the volume to a desired level, pretty straightforward. thanxs
Aug 09, 2010 | Cyber Acoustics Accent S-3022 Computer...
The volume of my built-in speaker is not loud enough
The volume os thes speakers are limited bytheir size.
If you have increased your volume control to the max, and they are still not loud enough,
I suggest you purchase a pair of acessary speakers, and use them instead.
Mar 14, 2010 | Compaq Presario PCCOM2232US Notebook
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Speaker volume too loud
Go to your bottom right task tray. Right mouse click on the speaker icon, select open volume mixer. You should be able to adjust to your preference from there. Hope this helps.
Apr 14, 2009 | Dell 5650 Computer Speakers
My Philips SBP1100 speaker' volume is not loud enough
Were they ever loud? If they weren't (which is my guess - judging by the picture) is that they are low wattage which essentially means that they are not intended to be loud. They are most likely to be used as a small compact, low-noise speaker for a smal MP3 player where high (club-vloume) wattage/volume is needed. If they used to be loud check the volume control on your laptop and check each and every setting that there is. One stupid little setting could be a big difference. Audio Properties in the control pannel could be helpful but don't mess with those settings in the control pannel unless you are almost positive as to what they are and what they do. You could cause yourself a bigger problem. Remember that most laptop speaker outputs are actually for headphones and are not intended to go super-high as they are designed for headphones and not to hurt ears at high volumes. Hope this helps. If not try checking back with me. Best of luck. Bonne chance!
Mar 09, 2008 | Philips SBP1100/37 Portable Speaker System...
26 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Damen Wong
Damen Wong
Tom Chichester
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
