SOURCE: just got a i9 phone want to insert the sim card
it doesnt matter which one you use. if you place it on the far bottem and with the chip facing up that is sim card slot 2 if you use the top slot actually elevated off the board a bit with the chip down that is sim card slot 2. the only thing that matters is when you set up your phone it gives you the option of sim 1 OR 2. I use sim 1 and have my 2 disabled. it will tell you once its inserted which one you are in on the front display exampl it will say sim 1 t-mobile. go to i9forum.com for detailed on this phone.
SOURCE: unsure about wi-fi capable phones without having data or internet plans on my cell service
You should have to have a data plan, I have heard of people using it without a data plan and not getting charged , but I have also heard of some that have, so I would just call AT&T and ask a representative that way if they say you won't get charged and you do have that conversation to lean back on to get the charges dropped. Hope this helps, sorry its not a definitive answer, but it varies. Just call and ask, they would know best.
SOURCE: I have a Dell Inspiron
no you dont you have wireless capability on your laptop. just turn on your wireless, click on it and it will show you all internet connections just click on your router name and it will connect. same when your away hotel will tell you their router name or (ssid) as its called.
hope this helps.
Testimonial: "Thanks- that clears it up!!"
SOURCE: MY SIM CARD WONT WORK IN MY HTC INSPIRE
switch off your mobile and keep away your sim, insert another working sim in the mobile and turn-on your mobile... if this sim is working, then turn off your mobile and re-insert your old sim. now it will work.
in case mobile is not working with new sim, you have to replace the "signal chip" of your mobile.
Best of Luck!
Pawan Verma
you require gprs setting to enable net services . ask ur network provider
