Error code E000110 in a Canon image RUNNER ADVANCE 1730i multifunction printer typically indicates a problem with the paper feed system. This error can be caused by a number of different issues, including a jammed or misaligned paper tray, a problem with the paper feed roller, or a problem with the paper feed sensor.
Here are a few steps you can take to try and resolve the issue:
Make sure that the paper tray is loaded correctly and that the paper is loaded according to the manufacturer's instructions.
Clean the paper feed rollers with a lint-free cloth and check for any debris or foreign objects that may be causing the jam.
Check the paper feed sensor for any damage or debris, and clean it as necessary.
If the issue persists, try to reset the machine. If the problem is caused by a misconfigured settings you can try to restore factory settings to see if the problem resolves.
If the problem persists and you have recently replaced the laser unit, check to make sure that the unit is properly installed and that all of the connections are secure.
Check the printer manual or contact Canon support, as they may have more specific instructions or troubleshooting steps that can help identify the cause of the issue.
It's also possible that the problem is not related to the laser unit but instead, it can be caused by a malfunction in other parts of the machine. For example, it could be caused by a malfunctioning paper feed motor, a sensor malfunction, or a malfunctioning control board.
I am really happy to say it's an interesting post to read. I learn new information from your article , you are doing a great job. Keep it up. https://www.myprepaidcenter.website/
The main thermistor has poor contact or open circuit,the thermal fuse has open circuit,the heater lamp as open circuit.The error reset in service mode :COPIER FUNCTION CLEAR ERR.
Hi there, iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
