Question about Watches
I can't set time zone. Watch keeps saying USA time zone not updated
    Top Expert:
  • Watches Master
  • 64,222 Answers
AND NOT TELLING US THE MAKE OF THE WATCH AND KIND HELP NEITHER US OR YOU
Posted on Mar 17, 2019
SOURCE:
  • 13434 Answers
SOURCE: WVA 107HA
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
Posted on Jun 09, 2008
escapement
  • 2338 Answers
SOURCE: silicon radio control watch, what # is the eastern zone
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Posted on Dec 17, 2008
  • 74 Answers
SOURCE: How do you set the watch for Central Time zone?
hi there wave ceptor watches vary wildly in their instructions, try going to www.casio.co.uk you will need the module number (found on the back plate) go to support and download the PDF manual (very easy to use), you may have to download adobe reader free of charge at www.adobe.com to read PDF files. good luck
Posted on Aug 21, 2009
cmcduncand
  • 714 Answers
SOURCE: on time atomic watch wrong time zone
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 24, 2010
  • 5370 Answers
SOURCE: I have a Casio 4304
It can be signal issue.Or you can try setting it manually, if its set on auto mode. Click this link directly,this is direct link for casio 4304 watch manual.:--- http://www.biro.ro/data_files/product_documents/file_83.pdf ------------ On page number 3 of the manual, there is procedure given to set the watch . --------------- this will help.Thanks.Helpmech.
Posted on May 06, 2011
12 hours ahead
I think you have the wrong time zone selected. Some zones are 30 min. off the rest. just in case
Instruction book page E-23. To turn auto receive on or off. In Timekeeping mode press D (Lower right) to display last Signal screen. It should say GET at the bottom and show the last time it updated. (Or ERR) Hold down A until the receiving indicator and current auto receive setting (ON or OFF) start to flash. Press D to toggle auto receive on. A again to end.
If you tried to make it receive manually this will be turned off. If the GET screen said ERR then it did not update and auto receive would still be off. I had to do the manual thing about 20 times before it updated. A upper left C lower left D lower right A upper right (light)
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Tru time atomic talking watch instructions
I own a independent watch (no name) I recieve as a gift. The only hint is on the face.is "TRUE TIME" and "Talking Watch". I enjoy tinkering with technology and so enjoy the watch. However it always says "USA time not updated", though the time is fine. So I found instruction. This site is concise and so might help others as well:
http://www.independentliving.com/instructions/756504.doc
Sep 09, 2013 | Watches
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Feb 25, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Silicon radio control watch, what # is the eastern zone
Dec 11, 2008 | Bulova Watch
WVA 107HA
May 27, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I set a LaCrosse WT-961 (B) watch?
This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
Mar 07, 2008 | La Crosse Radio Controlled Watch
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
