Video Game Consoles & Games Logo
B
BILLY ROBBINS Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT DO YOU USE WIRELESS MICROCON FOR ON XBOX 360?
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Mar 17, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152805
Points
4122
It requires an adapter that plugs into the system itself that the contriller itself "pairs" to. Do you have both pieces?
WHAT DO YOU USE WIRELESS MICROCON FOR ON XBOX 360? - 09d9ef89-be04-424f-81ce-139a9e1aad4c-nuhf2ssaswwsu1mfl2kxuue2-5-0.jpeg
5 Related Answers
A
Anonymous
  • Posted on Feb 06, 2008
SOURCE: programming Xbox 360 wireless controller
As Rizla said
however sometimes they just flash for a little while if this happens turn the controller off and try again and it should then work
n3zjp
  • 9 Answers
  • Posted on Nov 10, 2008
SOURCE: xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Anonymous
  • Posted on Feb 08, 2009
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
I bought this system recently, and it had the same problem from the beginning.
I opened it, and found that the problem was the F1 Fuse that is cutting the current. You have to open it and bypass (soldering) the two legs of the F1 Fuse.
This is how to open it: http://img22.imageshack.us/img22/6896/openingoi6.jpg
and this is the circuit: http://img14.imageshack.us/img14/231/receivereb4.jpg
Hope this will help ;P
Anonymous
  • Posted on Feb 22, 2009
SOURCE: wireless guitar for xbox 360
do you have an xbox 360 wireless guitar..if so then press the xbox button and when you do that press a little white button on the xbox 260 and it will work..you can do it for anybodys like if your going to a friend's house or something/
Anonymous
  • 8 Answers
  • Posted on Feb 23, 2009
SOURCE: xbox 360
You cannot use the netgear wi-fi adapter as the xbox 360 will not be able to detect it. I suggest buying the wi-fi adapter specifically manufactured for the xbox360
The pedals pin on Mad Catz MC2 MicroCon Racing Wheel for Xbox 360 is acting on its own so how do i fix it
try pressing the pin for 30 seconds before releasing. Also, you can detach it from your xbox 360 for 5 minutes before re-attaching the device to your xbox. Otherwise, you might need to send the device in for repair through xbox or your local Geeksquad/bestbuy.
Thank you.
tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
Just bought the orginal xbox 2.4 Version and it came with a wireless Madcatz controller that came with a receiver. The controller isn't working. When I plugged the receiver in the light flashed green and...
Hello Sandy,
I used to recondition these for resale. In almost all cases, I recommend purchasing an original Xbox wired controller. Understood this is not wireless, however it will enable you to use the Xbox.
New or refurbished controllers are relatively inexpensive and can be purchased at Gamestop, Amazon or eBay.
I hope this helps.
How do I connect my xbox 360 to the wireless internet?
For the Xbox 360 Slim, on the dashboard console:
1) Go to Settings
2) Select "System" to take you to the system settings menu
3) Highlight Network Settings and select it
4) Select Wireless Network to setup your wireless
For older Xbox 360 consoles:
1) Your will need an Xbox 360 Wireless Networking Adapter. Check online or your local stores to see if there is one available.
2) Once you have the adapter, simply hook it up to your xbox and follow the instructions at the top of this solution to setup your wireless through the xbox dashboard.
I dont know how to connect my mad catz steering wheel to my xbox 360?
if its wireless there must be a button to press then press the 1 on the xbox , not much help i know
I have wireless internet how do i get connect to the xbox 360
Depends if you have an Xbox Elite or an older Xbox 360?
If you have an Xbox Elite then there will be an in- built wireless, For older xbox 360's you will have to go and buy an Xbox wireless adapter.
If you go to settings, network settings, and select connect to xbox live via wireless then you will be prompted to input your security details for your Wireless and you should then be connected via wireless to xbox live.
2answers
3helpful
Wheel and Pedals?
I have the MC2 Microcon for the Xbox 360 and I've only used it on a PC, but I assume they are probably similar.
The pedals should plug into a slot on the base that the wheel sits on. On my model, it is on the bottom right side.
As for the plug that comes from the base with the wheel, you should have received an adapter that has a place to plug in the round cord on one side and a USB plug on the other side. The USB plug would go into your Xbox 360 or PC. This will connect both the pedals and the wheel.
Hope this helps!
1helpful
Microsoft Xbox 360 Wireless Controller for Windows
HI perform a system restore to before you installed the drivers
(start,Run System restore)
then reinstall them
should work :)
please rate .
Top You Video Game Consoles & Games Experts
vince
NOEL
NOEL
john h
Are you a You Video Game Console and Game Expert? Answer questions, earn points and help others
