730N RER SIRIUS RADIO WORKS GREAT. NAVIGATION DOESN'T SEEM TO KNOW WHERE WE ARE
SOURCE: Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
SOURCE: No voice during navigation
Have you tried to reset everything to Factory state? Both GPS and System? If it doesn't help then restore Sanyo map software from supplied DVD. Something must be missing or corrupted.
SOURCE: MBZ E320 CDI (2003), The CD, Radio and navigation system not work
Your radio/nav system needs a code. Go the your dealer's parts department , give them the VIN of your car( should be free $0). Punch in the code through the car radio and your radio/nav system should work right away.
SOURCE: Navi/Voice command problem
I have the exact same problem. If you have a solution can you please email [email protected]. Thanks!!!
SOURCE: Can't hear voice calls on my Samsung Tocco Ultra
The problem with your phone is that the earpiece of your phone is bad, that is why you cannot hear anything while you call or if you are called.
All you need to do is to change the earpiece of your phone and you will see that after changing it, you can hear when people call or when you are called.
Replace the earpiece as said and you will see that your communication with other people on the phone will move smoothly.
Take care.
