ALTANTIC BREEZE STANDING FAN, MO44550. fan goes on a medal pole which leads to plastic piece that tightens/loosens to raise/lower pole. screw in back of fan, does it tighten to pole to help hold it? fan to heaven for stand there must be missing piece! Help!
SOURCE: Driver side lower control arm, striped bolt.
can you email me a picture of the area ur talking about? blue_dragon45801@yahoo
SOURCE: how do you loosen the serpentine belt
remove air filter box completely. loosen o/s/f wheel. jack up the car, and secure. remove wheel. remove plastic shield to expose the cranckshaft pulley.check routing of the belt for replacement. on top of the tensioner there is a square, about 1/2 inch, place a bar in the square and gently push the bar towards the front of the car to release the tension, and remove the belt. change any defective pulleys. refit the belt leaving the top pulley till last.take up the tension of the tensioner, and then fit the remaining belt. make sure the belt is sitting right in it's grooves, and crank the engine first to make sure it is fitted ok. refit air box, plastic shield and wheel.
SOURCE: How do I tighten the fan belt?
yes there is a tightener for the efan elt the power steering belt ad the altanator belt, you loosen the side bolt then usa ratchech #12 to tghten ten all up, push on the belt and it should not deflect more than a half inch if it does it needs tightened uop and if you need help anddon't rste me I iwll no longer give you the informstion to complete the process to to do this, ove half of these free answers I don't get rate and for free it shld not be that hard to rare me to get more answers.
SOURCE: 2005 Nissan Sentra 1.8S, with AC - how to replace belts?
first of all you don't have to loosen the pulley,this will no solve the problem,well you already loosen the adjuster,good,bot thing you have not done i will tell you now,on the power steering pump where the belt pass there is also a bolt that hold it ,you must loosen that also,then after you will see the pump moving on the two position that means you will see the belt loosen on 1 position an d the position it will tight the belt,try that man.............
SOURCE: Upon accelerating, there is a chirping sound
the chirping noise you hear are the belts being loose,adjust the tension on the belts,if the pulley bolt has not loosened up by now ,you dont have a bolt problem-when you have the timing belt replaced ,have the mechanic put some lock-tite on the bolt
A standing fan is a portable fan that has a set of three oscillating blades on a long neck. The neck, also called the pole or the leg, is mounted on the floor. Standing fans have evolved from their origins as noisy accessories that blew away papers in their vicinity to silent fans whose direction can be controlled remotely. When placed at a convenient location, a standing fan can distribute air evenly to the entire room. Its speed can be controlled, and many standing fans can be programmed to stop at a set time.
