Video Game Consoles & Games Logo
Bret Boat Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code nintendo - Nintendo Video Game Consoles & Games
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Mar 17, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152845
Points
4122
What's the error code and what type of Nintendo device are you dealing with?
2answers
Do you have list of current Nintendo wi-fi connection-compatible software?
not sure if this link will help you outHow to get around the Wii Error Code 20110. Nintendo Wi-Fi Connection service for this software has been discontinued. Visit support.nintendo.com for a list of current Nintendo Wi-Fi Connection-compatible software. ... Anyway, it is still possible to play Mario Kart Wii or Super Smash Bros. Brawl online.
How to get around the Wii Error Code 20110 - St?phane Caron
https://scaron.info/blog/wii-error-code-20110.html... current Nintendo wi fi connection compatible software Google Search
1helpful
There was a error code using my nintendo network and the error code was: 022-2802
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=022-2802&system=3DS&locale=lang
Unfortunately, the error code is referring to something very vague, most probably on Nintendo's end. You will need to contact Nintendo support directly.
Have an error code on new Nintendo Wii U code 160-0104
Always check the Nintendo Website first for error codes.
This is from the Nintendo Website:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=160-0104&system=Wiiu&locale=lang
How do i fix the error code 013-9203 on a nintendo
The Nintendo Zone Viewer was not able to find a Nintendo Zone in range.
The Nintendo Zone Viewer application can only connect online from a Nintendo Zone. Click here for the Nintendo Zone locator. (Nintendo Zone is currently only available in the US and Canada.)
Error code 107-6961
That error code doesn't register as a valid code on nintendos site. Check it or try nintendos troubleshooting page
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
2helpful
When I try to get on the internet it says Error code 052001-1 and doesnt connect
I assume you are are referring to the Error Code: 052001 on the Nintendo DS? If so, here is specific information from Nintendo regarding that specific error.
Nintendo Error Code 052001
Regards,
Dan
2helpful
2answers
What is error code 220602 on the wii
220602 means there is a problem with the internet settings.
when entering your setting use manual settings to set up. manually entering the DNS settings when the screen comes up.
(note: errror code 32002 means the same thing)
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
