Https://www.youtube.com/watch?v=lfjC7gO1gDA
https://www.youtube.com/watch?v=TMqT83KcfG4
This manual shows where a reset switch should be. Sometime the motor will have a reset button on it. This manual also has a troubleshooting guide.
https://www.manualslib.com/manual/510190/Ryobi-Bts10.html?page=9#manual
I have had to remove the brushes from the motor and clean the sawdust out.
https://www.youtube.com/watch?v=hg_llZjxX18
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
SOURCE: ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
SOURCE: hi i need to rewire my ryobi table saw switch thanx lee
What I do is to take a photo of the wiring and effected area so I can refer to it when I get lost. Just replace each wire one at a time from the old switch to the new. Good luck
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
SOURCE: Ryobi 10 in Portable Table Saw modl #BTS12S won't turn on
Look for a trip switch on the saw motor
No reset! Thermal overload and cut out due to load. Let it cool down and make sure the blade is sharp and you are cutting within guidelines of instruction booklet.
