It could be a general hardware failure, maybe. How old is it? An easy assumption would be the filter capacitors on the power supply, but I would want to know more. If you take the rear lid off, look for larg-ish components that look like little batteries. They should be the larger ones, cylinder shaped, with scoring marks on the end. If they are bulged/leaking, they need to be replaced. Look up the uF number on the side and try to get something similair. If you can't get the exact value, alwayse go a little HIGHER in uF NOT LOWER. (Bang! Smoke! Flames!) Also be very careful that the voltage rating is high enough. To prevent this from happening agian try to source "low ESR" parts. These will have a lower seriese resistance and last a lot longer. They are a little more expensive.
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
SOURCE: Toshiba TV, no power, red light flashing
Unplug the TV for 2 minutes and plug it back on.
It should work.
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
SOURCE: i have a LG 32LG3000 LCD TV and the power light
Tries tv unplug,replug it back like about an hour later.See,if the tv will resetting self and working again.Not.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
