Washing Machines Logo
Ashlee Ward Posted on Mar 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you get to the coin trap on a capri washing machine
Chris Walker
Level 3:
Top Expert:
  • Washing Mach... Master 1,573 Answers
  • Posted on Mar 17, 2019
Chris Walker
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244864
Points
21965
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Sep 06, 2008
SOURCE: my "smart drive" excellence washing
Check the drain hose,
On many models there is a trap for foreign objects, usually you access it by removing the machine back panel
At the back of the appliance you can also access the pump, if you remove the two hoses you can check if something is stuck inside the pump.
Anonymous
  • 3 Answers
  • Posted on Nov 20, 2008
SOURCE: coin trapped between rotating drum and casing
Get underneath the machine and remove the big black house coming directly out of the drum,this is held in place with either a screw tie or pinch type tie.
Put the machine back level and see if the coins drop out (they should) or have a feel around inside the drum.
Please make sure machine is unplugged and empty before carrying out this procedure.
Some water will come out of hose.
Anonymous
  • Posted on Mar 10, 2009
SOURCE: open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
Anonymous
  • Posted on Jul 20, 2009
SOURCE: cleaned coin trap and now nothing is working.
just fixed mine took off 3 screws on bottom of washer removed panel unscrew round access in front of pump & found clogged debris also took all hose,s off & flushed out this cured the problem i think the clogging was cuased by using wrongt detergent
Anonymous
  • Posted on May 03, 2010
SOURCE: My Whirlpool Cabrio washer has some coins trapped
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
2answers
Where is the coin trap on a capri washing machine
Next to the drain pump between tub and pump.
5e error code
Samsung Washing Machine cleaning the pump & coin trap ...
? 5:11
www.youtube.com/watch?v=OofFb280Cn4
Jan 15, 2012 - Uploaded by whichwasher2007 Samsung Washing Machine cleaning the pump & coin trap .....you could try installing a new pump to avoid the 5E error, fixing the pump will ...
How can I repair a leak from underneath the coin trap of my Dyson Washing Machine?
Hi there, it's Jack at Dyson.
I can recommend a couple of checks that should help. Firstly, it's important to make sure the coin trap window is correctly rotated into position (one and a half turns clockwise) ensuring the childproof tab clicks into place. Check the plug is also pushed fully back into place: http://www.dyson.co.uk/support/cr01/cro1-flowcheck-white/maintaining-your-dyson-machine/check-the-coin-trap-step-1
It's also a good idea to check the seal within the coin trap is correctly in position, and hasn't been damaged in any way.
Unfortunately if the coin trap or surrounding components have been damaged, we've been unable to provide spares or servicing for CR01 or CR02 washing machines since December 2012. If you'd like to discuss this with the Dyson UK Customer Helpline, you're welcome to call us on 0800 298 0298.
How to clean a coin trap?
Thanks for your post, friend!
I understand that you looking for steps on how to clean the coin trap on your Frigidaire washer. Here are the steps to access the coin trap.
· Assure power has been disconnected to your appliance.
· Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure it is tilted up safely.
· Look inside on the bottom right hand side there is a black accordion piece. This is the screen trap or coin trap.
· Have towels available with you because any access water will come out.
· At the top of the coin trap where it is attached to the drum you will notice a silver spring and screw. Loosen the screw and wiggle the coin trap out.
· Clean the trap and follow these steps in reverse to reassemble your washer.
Best of luck! -Matt
I have ifb wasing machine which shows error code as E 6 where coin trap is free
if U R in india call 18604255678 or search for customer care # & call them
Washing machine not draining
see this causes and fix it. God bless you
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
My machine unable to complete program its saying check coin trap? where is the coin trap?
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
8helpful
Open coin trap
Coin trap
Bosch, the maufacturer @ 1-800-944-2904 says there is "no" coin trap so whatever is lost in the washer has been flushed down the drain , lesson learned : check your pockets and collars before you wash,everytime.
Top Washing Machines Experts
john h
