Nikon COOLPIX P80 Digital Camera Logo
Marie Fish Posted on Mar 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon coolpix p80 display and all pictures have a fish hole effect. Bright circle around subject and black all around it. Pics on memory card are beautiful full frame photos. Can't find a way to turn off this effect in the menu.
abdul rauf
Level 2:
Dedicated:
Visited the website for 20 consecutive days.
  • Nikon Expert 483 Answers
  • Posted on Jan 08, 2020
abdul rauf
Nikon Expert
Level 2:
Dedicated:
Answers
483
Questions
0
Helped
95815
Points
726
It could be lcd screen
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 19, 2007
SOURCE: memory card cannot be used
Follow these steps: 1. If you have a SD card reader, insert the SD card and look for it in Windows Explorer. In this case, mine was labeled F: 2. Right Click on the drive for the Card Reader (IMPORTANT) and choose FORMAT. 3. Format card with default settings. 4. Turn Camera on and go to MENU> FORMAT CARD 5. Before answering the next question, insert SD card into camera. You will hear it beep twice. 6. Choose FORMAT and the card should be formatted for use on the camera. Cheers!
Anonymous
  • 248 Answers
  • Posted on Jun 20, 2008
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Anonymous
  • 18 Answers
  • Posted on Dec 27, 2008
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Anonymous
  • 423 Answers
  • Posted on Feb 23, 2009
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Anonymous
  • Posted on Sep 13, 2009
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
2helpful
WRITE PROTECTED, HOW TO GET IT OFF OF MY NIKON COOLPIX P80??????????????????????????????????????? REFORMAT CAMERA---HOW????????????????? WHAT IS WRONG WITH MY CAMERA, WAS VERY EXPENSIVE AND I AM FURIOUS,...
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Im trying to get the pics off of my nikon coolpix p80 how do i do that?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
1helpful
I have pictures on my coolpix P80 that are showing on the camera, but they are not on the sandisc. Is there a way to transfer them from the camera to the disk? Help!!!!!! Jennifer
Download your Nikon COOLPIX L18 User's Manual from this LINK. Read pages 75, 76, 89, and 90.
It will show you the steps in transferring/copying of pictures from the camera's internal memory into your memory card. Other functions are also available for reading.
I hope this works for you. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
2answers
I have a nikon coolpix p80 and i need to transfer pictures form the camera memory to the memory card.. how do i do it?
You can do it through computer, using a memory card reader or there are many new laptops are with a inside memory card reader too, then you can transfer pictures from the camera memory and to the memory card.
My pictures wont download from my Coolpix P80. Sometimes it works after a few attempts but sometimes it won't detect pictures at all.
Hi
The problem with you Nikon Coolpix P80 needs to be narrowed down as it could be down to few issues.
  1. Faulty USB Cable - Can only narrow this down by trying the other solutions below
  2. Faulty USB port on computer - try another port or another computer?
  3. Static build up on the USB port. Switch the computer off AND unplug it from the mains. Leave it like this for 30 minutes to allow any static to disipate.
  4. Corrupt memory card - If you have a card reader you could try and read the card from the reader. DO NOT FORMAT THE CARD IF YOU HAVE DATA ON IT YOU WISH TO RETRIEVE. If required you may need to format the card in a PC and then place it back into the camera and format it in the camera.
Hope the suggestions help.
David
3helpful
I can not transfer my photos from my coolpix P80 to my computer. I installed the software and I still can not transfer them
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer. You can get the latest versions of Nikon's software from http://support.nikontech.com/app/answers/detail/a_id/61
My Nikon Coolpix P80 4G memory has become locked
there is an actual lock on your card on the side very small see if you may have locked it on accident
Nikon Coolpix S550 memory card problems
Your camera uses a different filing system than the other camera...they are not interchangeable.
1helpful
2answers
Camera not recognized by computer
Oh, I had I this problem last week. My drivers were outdated and I used this software:
http://www.windowsdriverhelp.com/landing/driver/wdh/driver.php?key=nikon p80
1helpful
Nikon Coolpix 4100 - transfer pictures to memory card
The easiest way is to transfer pics from the camera memory to you pc/notebook memory and then copy them to the the memory card thereafter with the help of a memory card reader.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
