Here are a couple of sites that offer manual. You may find yours in one of them.
Free User Manuals and Owners Guides ManualsOnline com
ManualsLib Makes it easy to find manuals online
SOURCE: When the car turns off the Sony CDX-F5510 AM/FM CD Player beeps.
yes if you are speaking of the beep go into menu settings where you afjust clock and such and turn off beep it is reminding you to remove the face..it is annoying
SOURCE: Installing Sony Explod CDX-GT170 CD deck
Red wire ignition, yellow wire constant hot, black is ground, the rest are speakers
SOURCE: I need a wiring diagram for the Sony explod
You can download the complete instruction manual in PDF format from Sony CDX-GT11W support website by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
SOURCE: I dnt know how to
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
