SOURCE: Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
SOURCE: Kichenaid side by side - new track for veggie drawer
get ur model number on inside wall of refer on sticker, go to searspartsdirect.com enter your model number and research the part u need then u can shop around locally or repairclinic.com or sears hope this helps
SOURCE: The storage drawer on my range won't slide properly.
Enter your model # at www.appliancehelponline.com for diagrams and illustrations. The plastic pieces are under the body parts diagram on the left hand side.
ADD74236201 is part number u will need. Have to replace the whole door. Just type that number in sears parts direct. 130 bucks
