Symptoms: -she said she walked by the furnace and noticed the air around/coming from the furnace was hot - temperature on the thermostat kept rising (it was in the 90s)? -no air was coming from vents/blower not working (will not run even when you turn thermostat to "on" or "auto") -Furnace would not turn off using thermostat (had to turn it off at breaker). Also, I want to mention that she's had to have the thermostat replaced 3 times over the last few years.
Here is a Installation Instructions that might help you
https://inspectapedia.com/heat/Intertherm-Electric-Furnace-Manual-KMACC.pdf
another one here
http://pdf.lowes.com/installationguides/093645900873_install.pdf
Testimonial: "Hey Robert, thanks for the links. I'm a bit confused as to how installation instructions will help but I'll read through and see what I can find! Thanks!"
SOURCE: Intertherm E1EH-015HA FURNACE no heat
Sounds like a downflow electric furnace? If so it sounds like you have 15kw worth of electric heat, you might have a defective heating sequencer, witch is what they call a dual on one plate.
SOURCE: Blower will not shut off on furnace.
If your blower will not shut off from the thermostat, you either have a bad thermostat or your red and green thermostat wires are exposed to each other.
SOURCE: I NEED A FILTER FOR MY 1991 HOBILE HOME FURNACE
Best things to do is find your Return grill in the home.
Get a measuring tape and measure the Hole size with the grill removed, Or filterback grill whatever the case.
Then simply go to a home retailer with the size, or in rare cases you may want to consider a Hogs hair washable filter that can be cut to size, to fit it perfectly.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
SOURCE: I have a mobile home with Intertherm electric
You could possibly have a bad sequencer. Turn off the power and check the normally open connections with an ohmmeter. If they are not open then it is bad.
